Fuel Pipe Replacement
Going to be replacing all of the fuel lines from rail to tank this weekend.
Does anyone know if you can get access to where they connect to the unit on top of the tank without actually dropping the tank?
Cheers.
Cheers.
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
Re: Fuel Pipe Replacement
I'm replacing everything (last MOT flagged that the pipes from the filter going back to the tank weren't too good).
Currently have a combination of metal, rubber & SS braided hose where I've replaced bits in the past so I've just bought an 8m length of SS braided hose to do everything from rail to tank in a continuous pipe (with the exception of splitting it at the filter of course).
For some reason I had it in my head that there was a cover (or something) under the boot carpet to get at the unit on the top of the tank, too much cheese perhaps?
It is a flexible one from the filter to the tank & that's the one that's perished on mine. Been meaning to replace the lot with a single at piece at some point though so now's as good a time as any.
Was just clutching at straws really to see if it was possible to get at the connections to the sender on the tank without actually dropping the tank.
No cheese, that's what you do in a Cavalier (non Turbo) under the rear seat. Not sure if any Calibras have the hole.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
I didn't think I was talking complete b*******.
Had a few Cavs in the past so that must be what I was thinking of.
Nice work fella
Billing Banner Erection 2014
Billing Chef 2014
See my V6 Cally here
Billing Chef 2014
To be brutally honest, I went for the flexible ones as it's less ballache to run them!
Being an occasional use car & not one that spends much time out in the elements, they should last me longer than I suspect they would in daily & nasty weather use. The stainless outer braiding should also offer a little more durability.
Please tell me you had more support than those axel stands or did you send those two lads under the car
More power than God
Looks quite steady to me and the wheels are still on
, but then I've seen some real horrors in jacking cars up
Two axel stands under the front subframe & two under the rear crossmember works for me but yes, wheels stayed on! It did fall off the last stand when I was lowering it back down though (front offside) but it did it so slowly it was quite amusing to watch.
The two lads are mine & they are banned from so much as sticking a finger under the car when it's up in the air. They're bloody useful though for passing me spanners, wheel nuts etc.
We used to call them apprentices
GreyDJ wrote:We used to call them apprentices
Started training my eldest a few years back.......
He's a fair bit bigger now so time to begin on the youngest too I think!
It's Mr D with hair!!!!
Billing Chef 2014
Billing Chef 2014
Users browsing this forum: Bing [Bot] and 38 guests
