Finally got the head off .
Re: Finally got the head off .
Well today i started cleaning up the engine block and engine bay. Heres some pictures of the days work
With the thermostat house removed.
Oil cooler removed. I also managed to clean most of the s**t out of the water and oil ways and i cleaned the pistons up.
I aslo started cleaning the engine bay with some tar and grease remover. Heres some after picutres. ( I forgot to take some before shot
tazz666 wrote:while you have all the inlets off,knife edge the inlet divider, and inlet ports, makes a bit off difference
When you say knife edge the divider and inlet ports what do you mean
in the divider bit ,the bit between the inlet manifold and the plastic bit you polish it up and where the inlets meet,you remove some of the metal and sharpen the air tracts it will help air flow as it separates into the according cylinder
tazz666 wrote:in the divider bit ,the bit between the inlet manifold and the plastic bit you polish it up and where the inlets meet,you remove some of the metal and sharpen the air tracts it will help air flow as it separates into the according cylinder
Oh i get it now
looking good already
rob
The head work has finally started
Smooth patio slabs so would be hard to damage the head
Robs-se wrote:Smooth patio slabs so would be hard to damage the head
could easily get some grit on face and put a rather deep scratch. a skim only takes a few
thousands of an inch of the face, bit of grit could do that
much better sitting on wood or even cardboard than a scratch surface
Fraz wrote:Robs-se wrote:Smooth patio slabs so would be hard to damage the head
Grit on my patio!!! not the way my wife makes me sweep it
that brings back memories or was it nightmares
v6 steve wrote:that brings back memories or was it nightmares
you loved doing it that much you done it twice did you not mate
Robs-se wrote:The head work has finally started![]()
Cylinder head on a patio slab
Cylinder head being worked on, on a patio slab
I screamed in despair.....
Really, really just...... no.....
Robs-se wrote:Grit on my patio!!! not the way my wife makes me sweep it
The only thing that should touch the head face is a skim tool or the head gasket. If the head must be placed face down then put it on a very soft surface, maybe like the piece of cardboard you have to hand....
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
The bottom of the head is facing upwards as you can see to the pictures. I only placed the head as shown in the pictures to take photos of the progress, as you can see im about to turn the head on its side. The piece of cardboard shown in the pictures is what i was working on. Maybe i should of left the head on the cardboard to take pictures so i guess thats my mistake. I'll say it again the work WAS NOT carried out on the patio. I hope this clears afew things up.
Rob-se9 wrote:The piece of cardboard shown in the pictures is what I was working on. Maybe I should of left the head on the cardboard to take pictures so I guess that's my mistake. I'll say it again the work WAS NOT carried out on the patio. I hope this clears a few things up.
Ahh that's cool then chief... Didn't know you were working on that
I now own this one.
I now own this one.
Users browsing this forum: Bing [Bot] and 21 guests
