help needed with my v6 please
Re: help needed with my v6 please
found it thanks
thank god my dads got an 2.5 omega for all these bits sshhhhhhh
iv tryed everything you guys have said and still no luck
so you have fitted so far
new plugs and leads
New Coil pack
New Crank sensor
New cam sensor ( is there not two of these???)
ICV
Ign Amplifier
checked
compression check on all cylinders
Checked the timing
and all air hoses
you say the plugs are covered in fuel...all of them or just one or two??
new plugs and leads
New Coil pack
New Crank sensor
ICV
Ign Amplifier
checked
Checked the timing
and all air hoses
there are two knock sensors but only one cam sensor i think
s**t you have confused me know
all of the plugs are wet with fuel it wants to start but just misfires and pops
rich30mex wrote:all of the plugs are wet with fuel it wants to start but just misfires and pops
The only thing that has a big effect on the fuelling is the ECU coolant temp sensor, and seeing as you have already checked/replaced the ignition side of the system, this would be where I'd go next.
http://www.v6calibra.net/ wrote:Coolant Temperature Sensors:
The V6 has two screw-in CTS's. However, they have nothing to do with controlling the V6 cooling system. They are used to monitor the actual coolant temperature in the coolant bridge and they report back to:
1: the dash coolant temp gauge
2: the main Motronic ECU
3: is a fan motor coolant switch
The main one to watch out for is the ECU CTS (with a blue coloured connector). The ECU needs to know the coolant temp to help it to adjust for engine running conditions (cold start, etc).. The dash gauge CTS has a single black wire connector.
ECU CTS Sensor Test
Disconnect harness socket and connect voltmeter across pins in the sensor plug.
Measure the resistance across the pins, this varies with the temperature:
17.8 deg C = 2530 ohms
22.0 deg C = 2250 ohms
25.0 deg C = 1680 ohms
Sensor does degrade in signal response with time, a failing CTS does not always raise a fault code it just provides the ECU with an incorrect coolant temperature. Will eventually supply a bad reading out of ECU tolerance (which is when a code is raised). Symptoms can include poor start, rough idle and rich running/poor petrol economy.
TEST :
20 deg C = 3.0 to 3.5 v DC
80 deg C = 1.0 to 1.3 v DC
110 deg C should give ~ 0.6v
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
still have in problems does anyone no ov any body who can come and solve this head ach of a problem im now stumped
Have you got the plug leads on the right way round? if you have fuel and a spark you should have igntion, have you changed the fuel pump relay? drivers side kick pannel. you can feel it click when the key is turned.
marko
where abouts are you ? im sure if you pay fuel we (me ally and fraz) would come down but no promises tho
v6 steve wrote:where abouts are you ? im sure if you pay fuel we (me ally and fraz) would come down but no promises tho
Doncaster
ill ask the guys if you want ?
yes please how much do you think your fuel will be ??????
whats your post code
depends if he drives the turbo down, you may need a bank loan lol
Allys Cally wrote:depends if he drives the turbo down, you may need a bank loan lol
lol it will be a turbo but the 4 door oil burner one tho
