Taking Car Abroad
Taking Car Abroad
Hi there I'm moving to Italy in 3 weeks and I'm taking my turbo with me, could anyone advise on any maintenence I should carry out first.I'll put a new T-Belt on and give it a service, but other than that I'm unsure.
Re: Taking Car Abroad
tyre pressures
tread depths
washer fluid
water pump (when doing the timing belt)
if its jacked to check for any play in any of the wheels. (grab top and bottom and try to move then the same side to side) if you get a couple of mm free play there is work to be done basically.
check for any leaks.
Is there anything about driving lenses alterations to be done for driving on the continent? since they drive on the wrong side the beam pattern has to altered possibly to avoid blinding people.
tread depths
washer fluid
- Club Member
KERR_SE9 wrote:could anyone advise on any maintenence I should carry out first.I'll put a new T-Belt on and give it a service, but other than that I'm unsure.
Yes. Sell it to me.
superfox233
Give me £3K and It's yours, although they seem to go for rather alot over there 7000 Euro or in that region!
KERR_SE9 wrote:Give me £3K and It's yours, although they seem to go for rather alot over there 7000 Euro or in that region!
yes but yours has the steering wheel on the wrong side, so you wont get that for it ....and its a long drive to Italy
so best get some sort of AA cover
make sure you alter the headlights
get a warning triangle
a hi vis vest for the amount of people in the car. and have them in the car not the boot
spare bulb kit as well
up to date first aid kit
make sure you have the correct reg plates on the car
I would have no qualms about driving mine that distance, so why worry if you know the car is well looked after
I took a car to Menorca last month, but that was a spanish Car so a little easier. I have taken out Insurance specifically for driving abroad.From what I've read I can keep it on UK plates for 12 months, Just have to wait and see what happens.
The weather should keep the tin worm at bay atleast!
if u want to register the car over there u will need continental headlight and if the car is moddified in anyway you will need all the tuv papers good luck
and u will have to payout for winter tyres most likely
have a good time get in with the club italia they come over to germany sometimes
ian
and yes the value of the cally is worth double over hear sure its the same in IT my german insurance valued mine at 10k + just hard to sell it with out all the revevent docs for my mods
ian
why do you need Continental headlights, calibra ones have a lever to switch them to left hand drive alignment
You got a pic of this Fraz? Fitting a HID kit and don't want stupid beam deflectors!
Ian I've read snow chains are a legal requirement in Italy, Is it the same for Snow tyres? From what I've researched Verona doesn't get alot of Snow
snow chains only for tracks
winter tyres to be on between certain dates but basicaly when temp drops below -3
ian
KERR_SE9 wrote:You got a pic of this Fraz? Fitting a HID kit and don't want stupid beam deflectors!
shows you in the handbook, its a metal lever that is right below the apature the bulb sits in
Cool, I will check that out, Slightly worried the Italians will reck my car, If they're anything like the Spanish, The take bumpers in there literal sense
You cannot insure foreign plates in Italy and you must own the car for at least 12 months outside of Italy before importing it i.e. transferring to Italian plates. So it is unlikely an Italian will buy it.
Get plenty of bulbs as outside of urban areas you must drive with headlights on all the time. You also need car docs such as insurance & ownership + driving license with you at all times; on the spot fines or even impounding if you are caught without them in a random roadside check which are very frequent.
Need warning triangle & a fluorescent bib for every person in car. Bring plenty of service spares - Vaux / Opel parts are expensive & rarely in stock. Chains ae only needed for certain roads at specific times of year, no need to worry about them for a few months, lol.
The youth are like magpies; they love shiny bits. Vaux badges, tyre caps, ICE doesn't last very long. Saying that , TWOCing is a relatively rare event.
Learn to live with tailgating and formation flying
Whereabouts in Italy are you going?
garyb
Users browsing this forum: No registered users and 59 guests
