part number required *early check strap cotter pin*
by k1nty » Wed Nov 03, 2010 2:48 pm
as title...just been to dealers but they only show the later 10mm type bolt for door check straps.i need the early cotter pin type for a 92.anyone help?
k1nty
Re: part number required *early check strap cotter pin*
by k1nty » Thu Nov 04, 2010 3:10 pm
hmn nut and bolt time i guess :(
k1nty
by MadOnVaux! » Thu Nov 04, 2010 5:25 pm
I'd have looked mate, but my EPC had a virus and Norton wiped the fecker! :(
by OPEL PARTS GREECE » Wed Nov 10, 2010 3:56 pm
CHECK LINK AND STRAP FITTINGS
90346767 1 60 912 SCREW, HEX.HD. C L1000001-C P1299999-P9299999 :dance:
90462820 (1 60 914) SCREW, HEX.HD. NLS.- USE 9116434 1 60 918 C R1000001-C R9000001-
OPEL PARTS GREECE
by k1nty » Mon Nov 15, 2010 3:05 pm
early cars dont have bolts through.everyone comes back with same thing??
k1nty
by Robs-se » Mon Nov 15, 2010 4:44 pm
You dont have a picture do you, i remember replacing something on my SE in that area. A picture might jolt the old memory. Is it the bolt holding it onto the door frame?
by tazz666 » Mon Nov 15, 2010 5:26 pm
mk3 cavaliers used to use the cotterpin
by Fraz » Mon Nov 15, 2010 6:08 pm
only shows a bolt for the Calibra but as Tazz said the Cavailer shows a pin
Part Number 9287242 PIN, STRAP TO CHECK LINK SUPPORT
Part Number 90195523 SLEEVE, TENSION, CHECK LINK STRAP TO SUPPORT
Cavalier
door strap1.jpg (19.76 KiB) Viewed 8921 times
Calibra
Check Strap 2.jpg (20.16 KiB) Viewed 8921 times
by k1nty » Mon Nov 15, 2010 7:57 pm
cheers lads,i ordered an early model cav one,doesnt fit.i will check if it was same pt number as yours fraz.the problem is the holes in the a_ post bracket are smaller than the ten milly bolt type as on later cars.check strap is obviously different too.
k1nty
by Fraz » Mon Nov 15, 2010 8:34 pm
what year is this car?? all Calibra's I have seen from K plate on have a bolt
by tazz666 » Mon Nov 15, 2010 9:06 pm
Fraz wrote:what year is this car?? all Calibra's I have seen from K plate on have a bolt
my old h reg had a cotter pin in the door check instead of a bolt
by Robs-se » Tue Nov 16, 2010 8:43 am
So did my SE and it didn't have the nylon washer either which is why i remembered it as it was different to the SE2 which has the bolt and washer.
I ended up changing the check strap as the hole where the cotter pin went through started to go square causing the door to crack. The pin was still ok
by k1nty » Tue Nov 16, 2010 9:33 am
mines a k reg aug 92.they have a tapered and convaluted roll pin affair.ill check frazs number against the ones ive bought.calibras had these 89 _92 but vauxhall dont remember lol.
k1nty
by Robs-se » Tue Nov 16, 2010 10:29 am
Silly question mate, but are you sure its the pin thats at fault and not the hole in the strap thats squaring off
by k1nty » Tue Nov 16, 2010 7:04 pm
Rob i dont have clicky doors,the pins are missings and the check straps need connecting
Fraz the 195523 pt number was the ones i ordered(cav ones) they are too wide and dont fit. i wonder if nova ones are similar ?
k1nty
