passenger door glass
by vcab1 » Sun Nov 28, 2010 4:03 pm
when the passenger door is opened and then shut
the top of the door glass sticks out, i have to lower the window
then close it again for the glass to sit in the correct location.
i just want the door to close with glass in its place
what causes this
is there a quick easy fix for this?
thanks
rob
vcab1
Re: passenger door glass
by v6 steve » Sun Nov 28, 2010 4:32 pm
sounds like the glass is out of line, when the door is open does the glass move from side to side ? you'll need to take off the door card and see if all's well with the runners
by vcab1 » Sun Nov 28, 2010 4:48 pm
v6 steve wrote:sounds like the glass is out of line, when the door is open does the glass move from side to side ? you'll need to take off the door card and see if all's well with the runners
ive just had a look, the glass moves but only very slightly, drivers door glass moves the same
but that sits fine.
the passenger glass (top corner) seems to go slightly higher than the door rubber
so when the door is opened it flicks the glass & when closed its to high to fit hence leaving a gap
recommendations ?
vcab1
by big_gordy » Mon Nov 29, 2010 2:00 am
u need to slacken up then tighten up the bolts on the doors and can be dam fiddely at times! just take your time and tweek em
i have had the same prob took ages to get it right and no fun if you try doing in in wet cold weather
Tigra Chequers 1.6 - # 2 Car
