Can you guess
Re: Can you guess
I thought someone might mention Superman (it's Daniel my eldest).
No, not that Steve (you know what i was doing)
Re: Can you guess
Didn't find one no, but have cured it.
I removed every hose, rebuilt the entire system end to end and double clamped (where room) every joint.
Boost has now crept up 1-2 psi and is making no squealy whistling noises as before.
5 hours work but worth it, as not only is it fixed, but each joint is hugely stronger that it was before.
Re: Can you guess
Andy your leak might be coming of the left hand side pipe it looks a bit loose
does Jane know where her curtains are
Re: Can you guess
good work mate lol for a minute then i thought you did a spray job hence the sheet behind the bumper lol
Users browsing this forum: Bing [Bot] and 16 guests
