Not boosting correctly again....
by Jamesyboy » Sat Nov 03, 2012 3:21 am
My turbo is holding back, and flutters whilst boosting..... Running eds phase 2, changed the plugs yesterday, seemed to run fine for a day, now has gone back to as it was. Its mainly in 4th gear it does this... any ideas??
Re: Not boosting correctly again....
by Jamesyboy » Sat Nov 03, 2012 12:58 pm
it is now back to how i got it from steve, 14psi overboost holds 12 (im not sure i trust the gauge as at phase 2 its should be at 19 overboost and hold at 14)...It was driving pretty well last night until on my way home, boost was all over the place, sometimes it was fluttering and holding back, sometimes it was just not boosting above 10psi Ive spotted the helper spring mod somewhere, i may give it a go, the rod is quite hard to move..... ive also just spotted it has a 3.0 bar fpr on it, im pretty sure it should be at 3.5 at phase 2... ive checked all the boost and vac hoses and seem fine to me....
by Jamesyboy » Sat Nov 03, 2012 1:17 pm
I need a what??
by Jamesyboy » Sat Nov 03, 2012 1:18 pm
yellow injectors....
by matty0785 » Sat Nov 03, 2012 1:44 pm
wide band lambda sensor and afr meter if messing with the fueling
by Jamesyboy » Sat Nov 03, 2012 1:46 pm
im not "messing" with fuel delivery, its fact that 3.5 bar pressure regulator is needed at phase 2
by v6 steve » Sat Nov 03, 2012 6:48 pm
james pull the plugs again have a look at them and post up some pics of them, i wont be surprised if youv burnt those cheap plugs already
by Jamesyboy » Sat Nov 03, 2012 7:28 pm
pics in 10 mins, ive just been an bought a new dizzy cap and rorary arm, and some injector cleaner.....
by Jamesyboy » Sat Nov 03, 2012 7:45 pm
by Callyman » Sat Nov 03, 2012 8:51 pm
James, The FPR is more thn likely 3.5 bar.
To make one into a 3.5 from a 3.0 it needs squashing in a vice with a socket, so reading the outside wont tell you what it is, unless you put a gauge on the fuel rail
Club Memberships
Club Memberships
by Jamesyboy » Sat Nov 03, 2012 9:10 pm
ok cheers, im still gonna get an uprated fpr, it can only be advantageous.... so has anyone any ideas what i could be my problem???
by Jamesyboy » Sat Nov 03, 2012 9:12 pm
My main issue is in 4th and 5th gears, in 2nd and 3rd its rare that i hit peak boost, and its just a spinning mess LOL but 4th, i can boost upto 4k, just as its going to hit peak boost, it just makes fluttery noises and holds back..... Help :-(
by Callyman » Sat Nov 03, 2012 9:17 pm
Amal valve playing up?
Club Memberships
Club Memberships
by Jamesyboy » Sat Nov 03, 2012 9:23 pm
how do i test thee...?
by Jamesyboy » Sun Nov 04, 2012 5:44 pm
Well, ive done the spring helper mod to the actuator, and my god, what a huuuuuuge improvement!!! So is a weak actuator.... Spools up at just under 2k instead of 3 before, and does just what it should, ive not given it beans yet as im waiting on the right plugs coming in, i dont wanna make it go bang!!
Users browsing this forum: Google [Bot] and 18 guests
