Air con removal
Air con removal
Just a quick question what do you have to do to remove air con from the v6 to run without it?
Vxmad
Re: Air con removal
It 'a relatively simple to do , you have to be careful when de-gassing
The main problem is that you'll need a non a/c engine mount as the a/c compressor is incorporated into the engine mount of your current mount and they are like RHS
If you want to loose the compressor then you need to fit a shorter aux belt and that fouls on the existing mount
Your only other option is to grind your mount down but that leaves it dangerously thin IMO
Sent from my iPhone using Tapatalk - now Free
Billing Banner Erection 2014
Billing Chef 2014
See my V6 Cally here
Billing Chef 2014
Re: Air con removal
I suppose till I can get a none ac mount I could just have it all disconnected ready to swap over cheers
Vxmad
Re: Air con removal
as Tim says the non ac engine mounts do come up every now and again. scrap yard hunts are probably your best bet, as thats how i managed to get a hold of my one
Re: Air con removal
Ok cheers if anyone hears of one coming available of know of any at scrapers let me know
Vxmad
Re: Air con removal
And yeah I've seen that and didn't want to try as seems allot of hassle may just get mate to fabricate one up
as from my other posts in a different thread I'm putting the engine etc into my mk1 astra as my v6 Cali is half the size it should be as was rear ended when was parked outside the misses house
Vxmad
