guys need a bit of help ....
n the two photos can you guys tell me if i have the torque wrench set to 8nm or 6 lbs of foot pound
am i right in saying that the newton meters is indicated on the black handle and the foot pounds is on the handle
Re: guys need a bit of help ....
irc the back is the 10ths ie 10,20 ect and the handel does the 1,2,3, ect so if you want 21lbs you put the back at 20 and the handel on 1
v6 steve wrote:irc the back is the 10ths ie 10,20 ect and the handel does the 1,2,3, ect so if you want 21lbs you put the back at 20 and the handel on 1
hes right.
k1nty
Baz, on the actual shaft of the wrench idoes it just show a foot pound scale?
BTW Steve is right, the rotating handle devisions are single ft/lbs
Baz, what torque do you need it to be set at?
he'll be doing the bolts on the cam covers
callyman wrote:Baz, what torque do you need it to be set at?
8nm
he has put metal covers on some time back but still has a wee oil leak so i think that this is what he is trying to sort out
arnt there two different gaskets?the ones destined for the vectra or the calibra ones...are the bolts the same...seem to remember someting different?
k1nty
gaskets are different bolts are the same
v6 steve wrote:gaskets are different bolts are the same
cheers steve,my mind is fuzzy ...had a drink...oops
k1nty
looking at the picture you have it set at 8 ft lbs ...but its hard to tell with the glare
look at the left scale passed then plus the handle..i.e 30 then 6 would be 36... you wont be far off there mate.
k1nty
Users browsing this forum: Bing [Bot] and 34 guests
