guys need a bit of help ....
Re: guys need a bit of help ....
by BazV6er » Sat Jun 05, 2010 4:21 pm
well ive finished about a hour ago , just washed the car , basically i used a bit of gasket sealer to seal the slightly ill fitting gasket ( so ive actually used the ones robv said to use the softer ones which he originally told me to use.
Waited 15-20 mins for that to set then applied a thin bit around the face of the gasket , a little more in the corners of the heads ,and the crescent bits so im just hoping its not gonna leak otherwise i dont know what im going to do .
but at least this time ive done it as most have said , i did the rear bank 1st after i was amazed how quick i got the inlet manifold off and did after lunch did the other one , gonna give it a littlle shortwait and drive home and hopefully it wont leak.
by Callyman » Sat Jun 05, 2010 6:31 pm
Baz, putting sealer anywhere on the outside wont serve any purpose at all
by Mark1 » Sat Jun 05, 2010 6:41 pm
callyman wrote:Baz, putting sealer anywhere on the outside wont serve any purpose at all
And will look a mess.
by BazV6er » Sat Jun 05, 2010 8:04 pm
ok lets get a few things correct , i havent used any sealer around the edges , i put sealer on the face of the gasket, head corners and the cutouts .as for the gasket its the correct fit as robbiev gave me as well as the cam covers , so i had two sets one that were quite hard but didnt fall out (robv told me not to use these so i did and today ive changed both to the others but had to make sure they stuck inside the grooves with a small amount of the sealant. .
now the great thing is theres small drops of oil dropping on path but tbh its coming from the wishbones areas so maybe when i had the oil cooler syndrome it went everywhere which it did anyway , a bit of a smell of oil but it seems to of been fixed.
:band:
heres a few pics :
now it may look slightly messy but from what i can see none of the gaskets are leaking.
Previous
Users browsing this forum: No registered users and 30 guests
