Corsa 1.4i 16v SRi
Corsa 1.4i 16v SRi
by Callyman » Sat Feb 20, 2010 8:40 pm
Going to see one tomorrow for Jane, anyone know of anything specific to look out for/check on these?
Re: Corsa 1.4i 16v SRi
by RobbieV » Sat Feb 20, 2010 8:41 pm
Give splinter a call, he has a corsa ;)
by Callyman » Sat Feb 20, 2010 8:44 pm
Cheers Rob
by BazV6er » Sat Feb 20, 2010 9:28 pm
i think there normally pretty good and reliable mate as tina had a corsa b and that was bulletproof
by Callyman » Sat Feb 20, 2010 9:53 pm
its an 02 plate, 4 door 1.4 eco 16v
by leelee » Sat Feb 20, 2010 10:21 pm
there usually bulletproof, but they do have some faults.eg gear linkage ,cv joints,broken rear coil springs,excessive play in inner tie rods,frayed handbrake cables,lamda sensors,front wiper linkage seize up.apart from that there a pretty reliable car.
by tazz666 » Sat Feb 20, 2010 10:34 pm
And there power steering pump fails,new column has to be fitted
timing chain tensioner fails reguarly make sure its done as it can be expensive to sort out
oil pressure switch fails and causes oil leak (a big one)
and make sure the recall has been done on the abs sensor
forget the timing chain bit as i see it is a 1.4 it has a belt
by Mark1 » Sat Feb 20, 2010 10:42 pm
Andy I had lots of Corsa C's and never had any problems with them and mine would have 4 or 5 drivers a day
by Fraz » Sat Feb 20, 2010 10:57 pm
power steering pump???? dont they have an electric motor assisted steering
by leelee » Sat Feb 20, 2010 11:09 pm
yes they are the electric motor is built into the steering column.same as a fiat punto,ive changed a few of them .
by tazz666 » Sat Feb 20, 2010 11:38 pm
Fraz wrote:power steering pump???? dont they have an electric motor assisted steering
yes they do fraz and they can fail,
by Fraz » Sat Feb 20, 2010 11:42 pm
well It ain't a power steering pump then as electricity dont need a pump :)
and it is usually the connection going it to the motor that causes the problems on them motors
by tazz666 » Sat Feb 20, 2010 11:44 pm
i know i know i was just being lazy not changinig it :D
by Callyman » Sun Feb 21, 2010 11:32 am
Thanks for the tips guys, we are off shortly to see it.
by trev150 » Sun Feb 21, 2010 4:46 pm
Did you buy it in the end?
