big thanks to FRAZ
big thanks to FRAZ
thanks for the lambda sensor worked a treat all running far better now
Re: big thanks to FRAZ
good glad it worked ...though far better implies its not quite right yet?
still got a sticky lifter to deal with
matty try some stp fuel injector stuff , it should do the trick
BazV6er wrote:matty try some stp fuel injector stuff , it should do the trick
For lifters ?
well aparently it can work especially if you get the wynns lifter stuff
is that wynns hydrolic lifter stuff any good or is it the good old pint of diesel through the engine oil trick again
do it right and change the lifters you tight arse
may take them out strip and clean them see if that works first
fraz you watch the pennies the pound watch them selves you know lol
