4 stud '2' 5 stud
4 stud '2' 5 stud
by bigdaz1987 » Sun Feb 06, 2011 1:50 pm
awrite guys i had the chance of gettin some nice wheels cheap only prob is they 5 stud vauxhall what will need changed on mine to make them fit and what donor car will i need to to get parts from at the scrappys
bigdaz1987
Re: 4 stud '2' 5 stud
by Mark1 » Sun Feb 06, 2011 2:11 pm
V6 or turbo Calibra or Cav.
by Allys Cally » Sun Feb 06, 2011 2:15 pm
remember you'll also need to change the discs and calipers aswell. unless you get your own discs drilled out for 5 stud hubs.
by bigdaz1987 » Sun Feb 06, 2011 2:18 pm
i have the v6 brakes on the front the now with the re drilled discs and could vectra stuff be used
bigdaz1987
by v6 steve » Sun Feb 06, 2011 2:27 pm
not sure about vectea stuff but using calibra or cav turbo is a straight swap i would use the whole rear arm and front strut that will save you trying to split hubs off the bearings
by Allys Cally » Sun Feb 06, 2011 2:34 pm
the vectra front strut is different so you wouldnt be able to change it straight over, as steve say changing the rear arm and front strut off a v6 or turbo is probably the easiest way of doing it.
by v6 steve » Sun Feb 06, 2011 2:40 pm
remember it was only the cav turbo that has independent rear suspension the rest just had beam axels
by Fraz » Sun Feb 06, 2011 7:51 pm
the GSI also has IRS
by MarkSE7 » Sun Feb 06, 2011 10:55 pm
Did the driveshafts have different splines on the hub end as well?
MarkSE7
