so who is taking the HID's out??
H.I.D take out or leave in
Will take them out and fit bulbs
0
No votes
Leave them in but change to bulb for MOT
4
44%
Leave them in till stopped and told to remove them
5
56%
Total votes : 9
by Fraz » Sun Nov 27, 2011 10:02 pm
as you may know there is changes to the MOT rules concerning aftermarket HID's
now there seems to be a conflict between the testers manual and the guide lines from VOSA (link below)
I think with the main problem is those that fit them in non projection type headlights, The Calibra I think since it has them and so long as your sensible with making sure the alignment is correct and use the headlight level switch if your carrying a load, should not really attract any attention
http://www.dft.gov.uk/vosa/repository/t ... ghting.pdf
Section 1.7 – Headlamps
To keep the test up to date with modern technology, new checks have been added in respect of High Intensity Discharge (HID) and Light Emitting Diode (LED) lamps.
HID lamps use a gas discharge system and require a ballast, igniter and special high voltage circuitry. They do not use a filament in the bulb, but have two electrodes in a glass tube filled with Xenon gas
A high voltage is applied between the electrodes causing an arc to form which ionizes the xenon atoms, vaporises the metallic salts and creates light. A high voltage, typically up to 20,000 volts, is required to strike and maintain the arc.
Compared with halogen headlamps, HID lamps are more efficient, have a longer service life and are much brighter; up to three times brighter in fact. The benefit of this extra brightness is that it enables drivers using HID lights to see approximately 30% further up the road ahead than for a halogen system.
The downside of this extra brightness is the potential to cause excessive dazzle to oncoming traffic. To combat this, HID headlamps often have advanced electronics that control the shape of the headlamp beam to avoid dazzle when the car climbs or descends hills and likewise when the vehicle is accelerating or braking.
Dazzle can also be caused if the lamps are dirty or aimed too high due to, for example, carrying rear seat passengers and/or heavy items in the boot. Vehicles with HID headlamps are therefore required to have a headlamp washing system (a wiper is not required) and be self levelling, which may be achieved either by the use of either headlamp or suspension levelling systems.
The presence and operation of these headlamp cleaning and levelling devices has been added to the test. Therefore, if a mandatory headlamp levelling or cleaning device is missing, inoperative or otherwise obviously defective, the vehicle will fail.
This raises the question of whether these checks apply to vehicles fitted with after-market HID lighting kits. These kits convert conventional halogen headlamps to HID Xenon and they are widely sold and fitted to vehicles used on the road. The Department for Transport considers that after-market systems should be required to meet the same safety standards as that applied in respect of these lamps at vehicle Type Approval. Therefore, in order to pass the MOT test, vehicles fitted with after-market HID systems would also need to be fitted with headlamp cleaning and self-levelling systems. Some high specification estate cars are fitted with a self-levelling suspension system and this would be considered as adequate for the purpose.
It is also worthy of note that a few high performance vehicles fitted with HID headlamps that have barely any luggage space and stiff suspension do not require a self-levelling system.
HID headlamps can be easily recognised as they generally:
take a few seconds to reach full intensity
have a bluish tinge to the light
have an igniter module/inverter behind the headlamp
may also have ‘DCR’ marked on the headlamp lens.
Headlamp washing and levelling systems are mandatory for all vehicles fitted with LED headlamp systems, although these are not yet widely used and only tend to be optional fitment on some executive marques. However, as LED systems improve and because they can be arranged in almost any design configuration, they are sure to become more common.
Where headlamp levelling or cleaning devices are missing or defective, but there is doubt as to whether they are required, the benefit of the doubt should be given and an advisory notice issued.
But the testers manual has
So who is going to take them out ...or leave them
Re: so who is taking the HID's out??
by v6 steve » Sun Nov 27, 2011 10:39 pm
ill be leaving mine in till the mot man says not then ill be putting them back in after
by Callyman » Sun Nov 27, 2011 10:54 pm
Mine passed 3 weeks ago with them in, nothing was said.
Re: so who is taking the HIDe out??
by v6 steve » Sun Nov 27, 2011 10:58 pm
coleman wrote:Mine passed 3 weeks ago with them in, nothing was said.
it doesn't start till April 2012 think in January they have to make them an advisory tho
by Callyman » Sun Nov 27, 2011 11:02 pm
That'd be why then I'd guess.
by craigyboy » Sun Nov 27, 2011 11:24 pm
Fraz how does that go if you have the angel eye
headlight units?
by v6 steve » Sun Nov 27, 2011 11:37 pm
craigyboy wrote:Fraz how does that go if you have the angel eye
headlight units?
most angel eyes are projector's, not sure what will happen come april i think it will bepend on the tester as its a bit of a grey area
by BazV6er » Mon Nov 28, 2011 1:34 pm
i wouldnt be without the HIDS , but i guess we will have to see what happens , if you do have to remove for MOT next year is it just a case of replacing the bulbs as im not sure if any of my wires were cutoff when robv did it .
by RobbieV » Mon Nov 28, 2011 4:42 pm
BazV6er wrote:i wouldnt be without the HIDS , but i guess we will have to see what happens , if you do have to remove for MOT next year is it just a case of replacing the bulbs as im not sure if any of my wires were cutoff when robv did it .
Plug and play Baz.
by Mark1 » Mon Nov 28, 2011 7:47 pm
He'll blow himself up :violence-impact: :-& :angelic-green:
by Allys Cally » Mon Nov 28, 2011 10:01 pm
i'll wait till i'm either pulled for it or the mot man spits the dummy out and asks for them to be changed :D
by Robs-se » Mon Nov 28, 2011 11:33 pm
Allys Cally wrote:i'll wait till i'm either pulled for it or the mot man spits the dummy out and asks for them to be changed :D
Ditto, but some of the new models HID lights always look maladjusted to me and more dazzling than mine
by MarkV6 » Tue Nov 29, 2011 7:57 pm
Same here....
But the hours I have to drive to and from work means I'll never see the rozzers :jail: and it also comes in handy having worked for the garage that does my mot's :shhh:
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
by Pinner-man » Wed Nov 30, 2011 1:22 pm
I had my car MOT yesterday - nothing was said about the HID headlights, in fact when I asked him about the HID's he replied he had not noticed that they were fitted to my car as it was a 1993 model, oh dear does that mean I have rubbish HID's. He did not know what was going to happen next year but said that he expected that the diferent "colours" could be banned.
As for for the dzzle issue, the real problems are caused by drivers who do not dip their main beams when there is on coming traffic.
Users browsing this forum: No registered users and 37 guests
