Newbie rolling resto.
Re: Newbie rolling resto.
by Cliff » Thu Aug 13, 2020 7:20 pm
I think Steva’s is that or more... he will be along at some point or one of the others.
by Cliff » Thu Aug 13, 2020 7:39 pm
Cliff wrote:I think Steva’s is that or more... he will be along at some point or one of the others.
I was wrong, his is 40mm with 19” rims - 215/35
by pigthief » Thu Aug 13, 2020 8:02 pm
Ok class I should have no problems with mine on 16's with 205/50/16's then
Sent from my HTC One using Tapatalk
Club Member
Club Member
by pigthief » Sat Aug 22, 2020 12:58 pm
Had a bit of time and have got one of my adapters made for the passenger seat and got measured for the rest. Looks like the outer ones will be able to be bolted to the new seats and the inner ones will be welded on. Dont have large amount of time so will take some time. Image
Club Member
Club Member
by pigthief » Wed Aug 26, 2020 4:21 pm
Cheeky delivery to go with the new springsImage
Club Member
Club Member
by pigthief » Tue Sep 01, 2020 4:44 pm
This happened today very happy it fits and works. But it needs the seatbelt rail changing so I can lower fully. Image
Club Member
Club Member
by Cliff » Tue Sep 01, 2020 6:10 pm
pigthief wrote:This happened today very happy it fits and works. But it needs the seatbelt rail changing so I can lower fully. Image
They look great fitted, no creaking springs either I’d hope!!
by pigthief » Sun Sep 06, 2020 7:50 am
Just for the record as I'm sure most of you saw on Facebook that both are in. One bolt to fit using an anchor nut and some strengthening of the adapter plates, then spray black and refit.
Sent from my SM-G935F using Tapatalk
Club Member
Club Member
by Cliff » Sun Sep 06, 2020 9:35 am
Looking smart - btw we do have many members that don’t have FB so the forum posts are very much appreciated
by pigthief » Sun Sep 06, 2020 12:03 pm
Few mins to fit this today, quite like it
Must start on swapping the new springs and shocks rather than the pretty stuffImage
Club Member
Club Member
by Cliff » Sun Sep 06, 2020 1:09 pm
Now where’s the fun in that - shiny things first then find the motivation mechanical and safety things
by pigthief » Sat Sep 12, 2020 10:22 am
So finally started on the suspension, though when you have to cut the old strut to be able to file a flat to get an adjustable on there to turn it then you know you not getting too much done.
As you can see it's VERY rusty, I had a leak into the top of the driver side strut top which was coming from the rubber blank further up the c pillar which I have sealed and you can see the damage it's done to the shock.
Few hours to get it changed and ordered some replacement lower rubber shock spacers, will wait for them and do the other side. Good news is I got the broken spring switched out for the 40mm lowered one can't wait to fight to get the others inImage
Club Member
Club Member
by Stealth69 » Sat Sep 12, 2020 5:58 pm
What year is your car mate.?
by pigthief » Sat Sep 12, 2020 6:00 pm
97 eco
Club Member
Club Member
by pigthief » Sat Sep 12, 2020 6:25 pm
Door check strap washers done, mudflap secured, now a break.
Should my new spring compress as much as it looks
Club Member
Club Member
