CweLibra Turbo.
Re: CweLibra Turbo.
Re: CweLibra Turbo.
Changed front brake pads
Got valentines day gift
i need to paint it as soon as i get my new front bumper
Borrowed some pictures of exact same lip (thanks D-Man hope you dont mind)
Im waiting for last edition bumper to arrive
Re: CweLibra Turbo.
Two days ago ive drove XE for the first time. No boost, gauge never goes over 0, nice boost gauge test
. Very boring, no mad accelerating over 3-4k rpm. Speeds equally and slowly reaches full RPM.
I was in luck finding it on the exit
Nice weather yesterday for trying out LE bumper. Its like new, not damaged. I didnt screw it, just put it to see how it fits so its not lined with the hood. Lines with headlights perfectly, even FMIC fits without cutting the bumper. Im thinking about black paint for the whole car!
H1 Cree LED kit 4200 lumens will arrive tomorrow. Its about ~70w, lights up instantly, longer lasting, less heating, nicer looking, less consuming bla bla bla
. Ive got fast bright AC xenon high beam, and xenon fogs now H1 LED low beam its gonna shinee
!1!!
Re: CweLibra Turbo.
Fog beams are in great condition, obviously because of rare usage, main beam is a bit fried, not so shiney inside so i might buy morimoto projectors soon. High beams are in average condition but with this AC HIDs they rock!
LEDs i got are actually 2200lumens and 6000K.
Removed headlights to fit LEDs easily.
Comapring ballasts and adapters, first is LED, second Xenon AC China CNLIGHT FastBright SLIM ballast, third ultra china VIP HID ultra big old b*stard.
Ive head 2 holes already for H1 low beam wires and H3 Fogs, LED cooler is buly so i had to cut another hole.
Fans can unfog my headlights too
Its meant to fit something like this, I might find this rubber seal, seen that on many vehicles but if i dont get foggy headlights i dont care.
This is main beam, not so shiney.
High beam not so bad...
Will fit them tomorrow!1!!11
Re: CweLibra Turbo.
Ive tested LEDs at night, it lights immediately, light is more pleasent, no xenon flicker BUT i didn't notice any improovement of light intensity comparing to cheap HID kits. Its clear that my low beam projectors are very bad so ive got Morimoto H1 BIxenon (with flaps) projectors and some badass LEDs for parking lights. I will fit these soon, ive used them on other cars and its nice improovement over old burned beams. Also with LEDs inside reflective coat will last much much longer. My high beam is extremely bright now with AC xenon and with this BI projectors flap will flip and ill have LEDs for the high beam too...
Checked last night, headlights arent fogging inside even tho ive cut hole in the back...
Re: CweLibra Turbo.
Ive been testing these leds and came up with some results.
Firslty by changing my projectors ive got 10-20%. Next i was testing LED vs average quality AC hid. AC Hid was 10-15% brighter.
Ive been driving for 2 nights and its not bad but since im going for best solution in term of brightness im going back to HIDs.
Seller will exchange this led set with Philips AC Can Bus HID set 4300K. LED is fun and starts instantly, but 2200lumens is 21w and it just isnt enough. I guess some 3600 lumens will perform great also i was expecting 4200 lumens but it was a mix up.
Ive wired bixenon projectors so flap goes down when i light high beam. Parking lights are awesome.
Morimoto BIxenon projectors look like a joke comparing to hella factory ones but hellas are not so reflective anymore so chinese crap lights much better.
Standard projectors
Drilled morimotos so LEDs will fit.
Morimoto on the left, hella on the right
Ive spent few hours on fitting these.
Most important thing is alignment, both projectors must be placed perfectly, so i used garage door to match height.
Ive modified cut off to RHD
Factory RHD
Morimoto
Cutting flaps
Now its LHD like from the factory
Some more flap cutting
In the end ive managed to break one glass
Bought one from the scrapyard, these are parking lights
Now cooler fits inside but anywayz im going back to xenon
So I did the testing, guess sometime soon LEDs will be much brighter and will start taking HIDs place, however H4 sets are much brighter because bulb is bigger. Also saw some 3600 H1's selling in China
Standard projectors
Factory RHD
Morimoto
Cutting flaps
Re: CweLibra Turbo.
Got "Philips" 4300K hid, thats it. Its awesome, MUCH better then LED. Projectors are great, got another headlight covers, now its sealed.
Re: CweLibra Turbo.
Ive got Vectra B Sport steering wheel. Its like new
This one is old which is 1cm bigger in diameter.
Ive had to grind coil a bit to fit. I will buy another coil with remote wires from vectra and pioneer-opel steering wheel remote adapter.
Re: CweLibra Turbo.
Thanks!1!
I have finally made FMIC pipes 55mm, used random hoses.
I will put this tophat when i get sone silicone hoses...
Re: CweLibra Turbo.
Not much has been changed, i drive it every day.
Got these chrome rings
Then i swapped the radiator with XE type, also bought steering wheel coil so i can wire wheel remote and put white LED soon.
https://www.youtube.com/watch?v=D6v4FwCtXng
http://www.youtube.com/watch?v=uvMmSRvkXVU
Re: CweLibra Turbo.
KS Head made me some mayonnaise, ran normal for a few months then i decided to search for coscast. Also KS didnt pass the pressure testing. Ordered GM stem seals, intake ports were polished. Finally got XE inatake camshaft retarded half a tooth. Runs amazing!1!
Old look
Polished bits
GM stem seals along with cosworth head
New gaskets n stuff
Managed to clean fuel injectors today
Hopefully soon ill mount bigger tophat, new RED silicone hoses, gonna polish letters on spark plug cap and repaint it in red, polish FMIC, etc...
Few random pics
Old look
Polished bits
New gaskets n stuff
Few random pics
Re: CweLibra Turbo.
Swap for bigger tophat and new hoses, also got this front bumper badge which will be used for my LE bumper one day
Had to add MBC cause my spring setup was overboosting too much in 6th gear, to accomplish 1bar in 3rd gear, 6th was going ~1.45. Amal was disconnected long time ago since its leaking on both my turbos and keeping bout 0.8bar. Now ima have stable 1bar boost no overboosting tho.
Users browsing this forum: No registered users and 99 guests
