Few new bits (ongoing)
Just waiting on a new gasket from VX
Re: Few new bits
What's that then?
Re: Few new bits
Mark, what you like aye?
Ive gone for the new top hat as it is a little bit enlarged and also has the dump valve fitting in it, as i didnt want to have it in the engine bay, as i'd have to have the inlet pipe cut/welded.
This way it's hidden under the cover.
Re: Few new bits
It's one of them nasty turbo things, I don't know anything about them.
Re: Few new bits
very nice mate
is that a bailey dump valve?
Re: Few new bits
Much better location for the dump valve. What size intercooler pipework you got, I ended up cutting the first section of the tophat upto the ridge to suit mine, bit less of a restriction too then.
More power than God
Re: Few new bits
I've got the EDS 2.5"/60mm, with a reducer, so will use that for now, but will get a straight piece later on.
Have you got the Regal/EDS one too? Not very smooth indside are they?
Re: Few new bits
leelee wrote:very nice mateis that a bailey dump valve?
Yes it's a Bailey, bought through LMF, as they are mega cheaper than anyone else i found.
Re: Few new bits
callyman wrote:I've got the EDS 2.5"/60mm, with a reducer, so will use that for now, but will get a straight piece later on.
Yea ive got the same one. Not the best of casting at all, was thinking about getting it smoothed on the inside at some point.
More power than God
Re: Few new bits
sounds like double dutch to me
Re: Few new bits
Mate of mine had a dig around and found me an old style oil cap, so out came the Autosol and here's the result. What ya think?
Also I got hold of some straight hose and have cut the Tophat back to the larger 60mm diameter so it's now less restrictive.
Re: Few new bits (ongoing)
looking good mate
- Club Member
Polished pipework from TX Autosport at PVS 2010
You may have seen this on the C20LET table they had there.
Users browsing this forum: No registered users and 42 guests
