v6
v6
by D_a-RR-e_N » Sat Jan 21, 2006 10:38 pm
my ecu light is on in my corsa ive flashed the codes and they are the following
16 - which i think is the knocksensor 1 (where is this located??)
13 - oxygen sensors (ive got a wire lose i know about)
31 - RPM signal ( crackshaft sensors) ?
would a dodgy oxygen sensors cos any of these or not ? (apart from 13)
D_a-RR-e_N
by D_a-RR-e_N » Mon Jan 23, 2006 8:14 pm
does anyone know where these sensors are?
D_a-RR-e_N
by RobbieV » Mon Jan 23, 2006 8:21 pm
Is this a V6 engine then ?
by thecrow » Mon Jan 23, 2006 8:25 pm
Code 31 will show up when you're flashing the codes with the engine not running.
16 is the front sensor IIRC
thecrow
by callymental » Mon Jan 23, 2006 8:31 pm
I have been trying to fix this on mine code 16.
Have been suggested to wd40 the contacts, and reconnect. There is a known fault in the wiring loom for this sensor. Will be putting mine back together later this evening, fingers crossed.
callymental
by RobbieV » Mon Jan 23, 2006 8:32 pm
This website will show you all you need to know about ECU faults, codes and sensor locations [img]/smile.gif[/img]
<a href="http://www.v6calibra.com/motonic/v6calibra_motronic_faultcodes.htm" target="_blank">http://www.v6calibra.com/motonic/v6calibra..._faultcodes.htm</a>
by thecrow » Mon Jan 23, 2006 8:38 pm
<!--QuoteBegin-callymental+--><div class='quotetop'>(callymental)</div><div class='quotemain'><!--QuoteEBegin-->I have been trying to fix this on mine code 16.
Have been suggested to wd40 the contacts, and reconnect. There is a known fault in the wiring loom for this sensor. Will be putting mine back together later this evening, fingers crossed.<!--QuoteEnd--></div><!--QuoteEEnd-->
Also, make sure its torqued up to the exact correct torque setting - they're very delicate in the way they work so it has to be spot on.
You're right though, the wiring gets screwed as it runs over the engine, gets hot, and breaks down.
thecrow
by D_a-RR-e_N » Mon Jan 23, 2006 9:07 pm
where is code 16 (knock sensor placed on the engine then??
ecu light stays off untill i rev it up then comes back on any ideas ??????
thanks guys ......
D_a-RR-e_N
by RobbieV » Mon Jan 23, 2006 9:35 pm
If you look at the website all the info is there, Fault code 16 is number 1 knock sensor which you can see on the pic [img]/smile.gif[/img]
by callymental » Mon Jan 23, 2006 10:47 pm
Mine is showing signs of being fixed with a little wd40, not convinced yet, but will have a decent run tomorrow.
callymental
by D_a-RR-e_N » Tue Jan 24, 2006 12:25 pm
spot on ill have a go at cleaning it up and hopefully may come out of limp home mode ! and i can have a go and see what the motor is really like...
thanks alot
D_a-RR-e_N
by D_a-RR-e_N » Tue Jan 24, 2006 1:16 pm
no go tryed cleaning it up and it ticks over ok, but as soon as i put a bit of throttle on the ecu light comes on again. if i get a new knock sensor willl this solve the problem ?
D_a-RR-e_N
by D_a-RR-e_N » Tue Jan 24, 2006 1:37 pm
are they the same as vectra or anything else ?
D_a-RR-e_N
by Cozy » Tue Jan 24, 2006 1:59 pm
<!--QuoteBegin-D_a-RR-e_N+--><div class='quotetop'>(D_a-RR-e_N)</div><div class='quotemain'><!--QuoteEBegin-->no go tryed cleaning it up and it ticks over ok, but as soon as i put a bit of throttle on the ecu light comes on again. if i get a new knock sensor willl this solve the problem ?<!--QuoteEnd--></div><!--QuoteEEnd-->
did you disconnect the battery for 1/2 - 1 hour after you cleaned the connection, you need to do this to clear the fault code, try it after you have d/c'd the battery to make sure before you go ordering new sensors
Cozy
by D_a-RR-e_N » Tue Jan 24, 2006 2:55 pm
does it half to be 30mins cos i have discontced ecu every time and ecu light goes off untill i rev it up again.
D_a-RR-e_N
Users browsing this forum: No registered users and 42 guests
