Trip computer - Switch problem
by craigmcd82 » Thu May 20, 2004 10:36 am
IIRC the switch is close to £50 from Vx. Im sure someone will correct me if im wrong tho!
I bought the comp and switch together for £35. Why would someone sell them separately? Make more money I guess!! :?
Then again, If i sold mine, i wouldnt be able to sell the switch or id be left with a hacked up hole in the console from the stanley knife butchery!!
craigmcd82
by Leigh » Thu May 20, 2004 11:18 am
OUCH!!! didn't realise it was that expensive.
I can see why in some ways people might auction them seperately in case someone has a need for just the switch, but I suspect as you that it's just to make more money.
Didn't work that time tho did it!
Leigh
by Tattooman » Thu May 20, 2004 1:22 pm
it's not £50. i've just called in to see just how much they are, they said they would do me one at trade price, £45 plus vat!! normally the fuel computer switch sells for £68 plus vat!!!
Tattooman
by craigmcd82 » Thu May 20, 2004 2:06 pm
:shock: :shock: :shock:
Daylight Robbery!!!
craigmcd82
by Leigh » Thu May 20, 2004 3:04 pm
FFS!!
If it's only the two push buttons in a unit I'm sure you could rig something up if someone knows the right pin connections, just it wouldn't blend in as well..
Leigh
by calibradeek » Thu May 20, 2004 10:20 pm
i just got a computer and switch from a carlton for £12 from the scrappies. The calton switch does not have correct plug so a bit of DIY wiring is needed the colours are the same just strip bback the wires and solder together mine works pervect all i need now is the chip callibrated to my car is there someone on the site who does it?
calibradeek
by RobbieV » Fri May 21, 2004 12:33 am
Hi, have a nose at this site
<a href="http://www.abs-zero.com/FCprogramming.htm" target="_blank">www.abs-zero.com/FCprogramming.htm</a>
and send Ian an email, he done mine for me very cheap and a quick turnaround [img]/smile.gif[/img]
Cheers Rob
by calibradeek » Fri May 21, 2004 1:22 am
cheers mate
calibradeek
DC Update on the Rear Panels?
by Tattooman » Tue May 25, 2004 5:02 pm
how do you set the clock on the trip computer? i know the 2 tiny holes on the switch are for the hours and minutes and i can set the time ok, but then the clock doesn't advance it just stays on whatever time i set it to. after setting time do you then have to press both tiny buttons together?
Tattooman
by Kieran_Burns » Tue May 25, 2004 6:05 pm
no, press the select button.... and it starts the clock (this catches a LOT of people out)
Kieran_Burns
by Tattooman » Tue May 25, 2004 11:13 pm
Kieran, the select button being the larger, flat one of the two?
Tattooman
MegaVaux - Great Service
by craigmcd82 » Wed May 26, 2004 11:17 am
The select button is the concave one, I think its larger. Its the one you use to scroll through the functions of the FC [img]/smile.gif[/img]
craigmcd82
by calibra » Thu May 27, 2004 12:14 pm
Hello
Thanks for answering my question
This is what I have found. The wiring loom from the white block to the computer does not exist.
I went down the breakers and found a cav 2.0 16v.
I took the hand-break console out and found the loom. The loom I found (approx 5 wires) does not exist on my cally.
so I cut the plug off. All I need to do now is find out where the 5 wires go to and how to sire them up.
I will submit photo's over the weekend.
Thanks
James
calibra
by calibra » Thu May 27, 2004 12:15 pm
P.S - My cally is 2.0 16v 1995
calibra
by V6_E » Wed Jun 02, 2004 10:29 pm
Didn't know the spare trip comp and switch i have from a cally turbo was worth that much :shock:
E
P Reg V6 In Titanium Pearl thats going to be stripped for parts now after being let down on it being bought whole :(
Now in a Crono yellow 2010 Seat Leon Cupra R with all the toys
