Heater Control Panel
Re: Heater Control Panel
by HOT-ROD » Sun Sep 23, 2012 3:07 pm
Thats how their wired up mate they work off the ignition and all the others work of the sidelights thus being able to dim them and not the heater controls!
by SAMARAI » Sun Sep 23, 2012 11:42 pm
It seems silly though that the fan controls and slider controls are not dimmable. So on all Calibras its like this?
via Tapatalk 2 for Galaxy Mini ;)
by SAMARAI » Tue Sep 25, 2012 1:50 pm
No wonder the Bulbs in that Centre console blow since they're 100% on if ignition is on!
by HOT-ROD » Wed Sep 26, 2012 5:07 pm
Yup! Prob wouldn't take much to modify the wiring! :think:
Re: Re: Heater Control Panel
by SAMARAI » Wed Sep 26, 2012 5:24 pm
HOT-ROD wrote:Yup! Prob wouldn't take much to modify the wiring! :think:
Has it been done before??
by HOT-ROD » Wed Sep 26, 2012 6:00 pm
Would imagine so! :wink:
by SAMARAI » Wed Sep 26, 2012 6:08 pm
Hrmm well its a good thought. I'm going to look into that.
by Fraz » Wed Sep 26, 2012 6:27 pm
I did it a long time ago ...there is a connection on the heater panel that the purple wire goes to, has a two pin white connector. IIRC one side is the supply feed (ignition live) and all I did was dissconnect that and then run a wire from the clock illmination to that supply feed, leaving the connector disconnected of course
I think you can get to the connector once the clock/fuel computer/D.I.D is out the way
or you just cut the live feed at the bulb holder if your taking it off to change the bulb and do the same ..take your choice
by EddeyDancer » Tue Nov 06, 2012 2:53 pm
I also fitted an LED Bulb in the 'Heater Control Panel' recently...
It's NOT as difficult a job, as I was expecting it to be...
So anyway, here's some more photo's of this Job...
by SAMARAI » Fri Nov 09, 2012 3:20 am
Thanks guys. Might try my hand at it and see what I can go :p
by MadOnVaux! » Sun Nov 11, 2012 5:50 pm
What LED bulb is it for the panel?
by Fraz » Sun Nov 11, 2012 6:11 pm
509 type
if your wanting the one I used there is a link page 1
by MadOnVaux! » Mon Nov 12, 2012 4:54 pm
Fraz wrote:509 type
Cheers Fraz....i missed the link sorry.
Thats a good bulb with the 3 LED's, rather than some i've seen with one LED so you end up with the brightness centered in one spot.
Previous
