Immobilizer problem
Re: Immobilizer problem
by rich30mex » Thu Aug 17, 2017 10:09 pm
Right fitted a new crank sensor tonight and still no joy. I have got a great spark on all 4 plugs but can not here the pump prime and there's still no fuel at the rail going it check the pump connections tomorrow evening as I need this running soon ffs
by Cliff » Thu Aug 17, 2017 10:10 pm
rich30mex wrote:Right fitted a new crank sensor tonight and still no joy. I have got a great spark on all 4 plugs but can not here the pump prime and there's still no fuel at the rail going it check the pump connections tomorrow evening as I need this running soon ffs
Fuel pump relay?
by Allys Cally » Thu Aug 17, 2017 11:41 pm
Fuel pump relay?
as Andrew says, be easier to check this first give it a hit as you turn the key over
by rich30mex » Fri Aug 18, 2017 8:38 pm
The relays clicking in and out when I turn the ignition on might swap it for a piece of mind I'm going to check the power to the pump next I'll keep you informed and thanks for the advice guys
by sealeysonic » Sun Aug 20, 2017 6:55 pm
Do you know if the injectors are firing....?
by rich30mex » Sun Aug 20, 2017 10:26 pm
Problem fixed it was a Loose plug to the pump thanks for the help
by cal16v » Sat Aug 26, 2017 11:55 pm
Happy you've sorted this Rich. Enjoy :clap:
Previous
Users browsing this forum: No registered users and 63 guests
