I've got problems!:(
by Phil » Fri Nov 18, 2005 5:56 pm
I replaced my alternator. The new one was a deco remmy (spelling??) they are re-con units. That's what they do apparently?!
That was knackered because it had been on the shelf so long. All the bearings had dried up. It was noisey and then started failing a few weeks in. It went back. I replaced it and the one I have now if fine.
Could just be bad luck mate.
Phil
by j4mes » Fri Nov 18, 2005 5:56 pm
about 45 - 55 quid each. you nutter
j4mes
by jimbohotpants » Sat Nov 19, 2005 4:30 am
got one for £38! and I've gotta drive all the way to bristol to return it [img]/sad.gif[/img] The other one was outa my Landrover, so back there it goes![img]/biggrin.gif[/img]
jimbohotpants
by Peachperformance » Sat Nov 19, 2005 7:35 pm
Well at least you've got to the bottom of the prolem now. As others have said it is not that uncommon to have problems with replacement alternators. Unless you want to pay £150 for one they will all be remanufactured. As such the bearings etc. will all be remanufactured. However a lot of the time the voltage regulators remain untouched.
Peachperformance
by andyzeb » Sat Nov 26, 2005 3:01 pm
had the same problam with my cally. it was the earth from the gearbox. put a jump lead from the battery earth to the alternater body and see if the voltage rises
andyzeb
by jimbohotpants » Sat Nov 26, 2005 3:31 pm
well, I earthed the bulb directly to the alternator body and it lit up..... thought that was a good enough test of the alternator earth really..... perhaps not?
anyway, its in now being swapped for new alternator, so if it comes back still with problems I'll have another gander at the earthing.
Cheers [img]/smile.gif[/img]
jimbohotpants
Previous
Users browsing this forum: Bing [Bot] and 15 guests
