Engine Starter Button
by Robert_Dale » Mon Apr 11, 2005 7:51 pm
Right,
I want to do an Engine starter Button Mod!!
BUT i want to get rid of having a key completely (I have enough security to ensure the car will be ok)
No i can understand how to start the engine from the guide on here BUT how would i turn it off if i have no key!!!!
I was thinking a button to start and a button to stop if thats posible?
Rob
Robert_Dale
by BazV6er » Mon Apr 11, 2005 7:54 pm
rob have you looked at the section in the how to guides?theres something in there
by Robert_Dale » Mon Apr 11, 2005 8:04 pm
Yeh i have mate, but it doesn't tell you how you can stop the engine, i want to get rid of the key if that makes sense.
so no key - start the car - then i need to be able to stop the car?
Robert_Dale
by projectx » Mon Apr 11, 2005 8:32 pm
You could just hook another switch into the ignition wires to break the circuit. You'd just need to hold it down long enough for the engine to completely stop. Not too sure about the logistics but I'm sure it's possible.
projectx
by fatnic » Mon Apr 11, 2005 8:52 pm
What about a push button on the ignition line? Push once, switch stays in, ignition on. Press again, ignition line broke. Engine stops.
You can probably find one at Maplin. (<a href="http://maplin.co.uk" target="_blank">http://maplin.co.uk</a>)
I want one now!
fatnic
by Chavtastic » Mon Apr 11, 2005 8:54 pm
DC is the man for this - he uses a card or something doesn't he?
by fatnic » Mon Apr 11, 2005 8:58 pm
<a href="http://www.maplin.co.uk/Module.aspx?ModuleNo=34859&TabID=1&source=15&WorldID=3&doy=11m4" target="_blank">http://www.maplin.co.uk/Module.aspx?Module...ldID=3&doy=11m4</a>
This would be ideal I think
fatnic
by daddycool » Mon Apr 11, 2005 9:12 pm
<!--QuoteBegin-CalibraTurbo99+--><div class='quotetop'>(CalibraTurbo99)</div><div class='quotemain'><!--QuoteEBegin-->DC is the man for this - he uses a card or something doesn't he?<!--QuoteEnd--></div><!--QuoteEEnd-->Yes I do! [img]/biggrin.gif[/img]
daddycool
by Naz » Mon Apr 11, 2005 9:23 pm
Rob:
The guide you have read is about fitting a start button in conjuction with the key as well as you still have to tunr the key manually to position 2 of the barell then press the button.
But if you want to completely remove the barell all together, 1stly you need to remove the barell, which means you won't have any steering lock and there will be a hole where the barell used to sit.
Then what you do is to install 3 buttons( 2 flip switches and one push button). The flip switches you have to turn on in sequence so that the ignition is live, then you press the starter to start the engine.
To switch off you simply flip the two switches to off position and this will stop the car.
Your best bet is to buy a panel from motosport shops, then mount that in the centre console where your ashtray is. Thats what i have done to my car. I will try and see if i can find a pic of my car with the switches and post up here
Naz
by Naz » Mon Apr 11, 2005 9:40 pm
Naz
by Naz » Mon Apr 11, 2005 9:54 pm
or this one:
Naz
by Robert_Dale » Mon Apr 11, 2005 10:04 pm
mate that is about spot on for what i want - have you got a wiring diagram?
Robert_Dale
by Naz » Mon Apr 11, 2005 10:07 pm
I don't have a wiring diagram as such. It really depends on what type of switch you go for, you can either get like mine which is a 3 switch figure or you can get 2 switch figure.
They all come with a std wiring diagram, which if you good with a multimetre then you won't have a problem with
However if you get it and still not clear, then drop me an email and i will send you more details about how to wire it up
top of my head by the way i think the switch panel was about £30 for this one.
Naz
by icewizard » Mon Apr 11, 2005 10:07 pm
Don't insurance companies get a bit worried when you take away the need to use a key?
Bear in mind to be able to cut the ignition circuit you would need a reasonably high current switch or a relay And that the present ignition switch disables all fans(Heater & radiator) during cranking.
Sounds like a good idea though.
icewizard
by daddycool » Mon Apr 11, 2005 10:45 pm
You can see mine on the top left of this pic.....
And this is the ignition barrel....
daddycool
