turbo timer help ...urgent
by CAL.16V » Mon May 02, 2005 6:43 am
all i want to know is how do i hook the timer up to work with the standard alarm???
will it work by hooking it up to the sterring collum wiring ie. accessories, ignition and constant 12v? or do i need to hook into somewere else??
CAL.16V
by Admin » Mon May 02, 2005 9:55 am
Do you mean so that you can arm the alarm and leave the turbo timer to cool the car down?
Admin
by CAL.16V » Mon May 02, 2005 2:47 pm
yes thats what i am wondering...
bcause i have a spare key and have noticed that i can lock the car with the car running with keys in ignition which is pretty much the same a s a turbo timer right?? but the light for the alarm does not flash.... wll the alarm be armed if i just normall wire up the turbo timer to the steering collunm area for the ignition switch for 12V constant, accessories and ignition???
thanks
CAL.16V
by 4x4Turbo » Tue May 03, 2005 9:37 am
my turbo timers wired up to the ignition but when you turn the ignition of theres abut a 1 second delay before the turbo timer kicks in, its obvouisly wired up wrong but ive tried re wiring it different and had no joy, so if you get yours sorted id be gratefull if you could tell me which wires you have tapped into as its driving me mad!!
4x4Turbo
by CAL.16V » Wed May 04, 2005 5:03 am
anybody else??
i am thinking i might sell it as theres no point wating around outside the car to lock the car when i can just wait inside the car for it to cool down????????
CAL.16V
by Naz » Wed May 04, 2005 2:28 pm
Hey Mate
If the turbo timer is not part of the alarm then unfortuntely there is no way to wire it up so you can arm the car whilst the engine is running.
When the trubo timer kicks in, the power to the ignition is still on, so you won't be able to arm the car as the alarm thinks there is still key in the ignition.
Like trying to press the arming switch whilst the engine is running.
Naz
by CAL.16V » Thu May 05, 2005 2:16 pm
damm...guess i gotta sell it then or wait for an aftermarket alarm..
tried running the car today and locking it with another key then taking the key out of the barrel and the car turned off and was locked but the alarm light just not flashing, it was just lit up red so dont think it was on...it probably registered an error or something..
so now........
does anybody have a turbo timer and a standard alarm working in a calbra 95/96 4x4 turbo???
CAL.16V
