Glovebox and dome light
by tsdinos » Wed May 04, 2005 3:03 pm
My glovebox light isnt working althought the bulb seems fine. I also checked its base for connection problems but it seems fine too. Could this be a blown fuse? If so wouldn't this affect something else too? Also is the glovebox bulb the same with the dome and boot bulb? Is it 36mm-39mm or 41mm-44mm? On ebay they advertising calibra's interior lights with 36mm-39mm bulbs but i measured mine and its slightly 45mm. What bulbs should i get?
tsdinos
by tsdinos » Wed May 04, 2005 5:12 pm
Does anyone knows a website that lists the type of bulbs that calibras use?
tsdinos
by tsdinos » Thu May 12, 2005 6:12 pm
I posted this about a week ago.. So no one has any suggestions to help???
tsdinos
by Fraz » Thu May 12, 2005 6:25 pm
never seen this...the glove box light should work only when the igntion is on IIRC, and has a small plunger switch to provide the earth conection
the size of the bulb is same as the boot light and interior bulb and its abou 43mm...cant help with list though
by tsdinos » Thu May 12, 2005 6:32 pm
I took the bulb base out and check it. Everything seems to be connected and the bulb also seems to be ok. Could this be a blown fuse? But if it was a fuse wouldnt this affect something else too?
tsdinos
by Fraz » Thu May 12, 2005 7:19 pm
have you checked the supply and earth?
have you swapped the bulb with say the boot light to check the bulb is working ..bulbs can look ok but still not be working.
<a href="http://www.clubcalibra.net/forum/showthread.php?t=9540&highlight=list+fuses" target="_blank">fuse list</a>
