Fuel - temp computer
by niggy0 » Tue May 17, 2005 5:02 pm
does any one know why my fuel temp computer has stopped working - the entire display is blank apart from the clock which is working fine........
it's not the usuall --:-- in the diplay there is just nothing no functions or anything (other than the time)
niggy0
by niggy0 » Fri May 20, 2005 4:30 pm
looks like the reverse lights may have gone as well (are they on the same fuse/earth wire does anyone know - could this have anything to do with my auto box not working ('s' BUTTON FLASHES N HAVE TO CHANGE GEARS MANUALLY)
niggy0
by RobbieV » Fri May 20, 2005 6:43 pm
<!--QuoteBegin-niggy0+--><div class='quotetop'>(niggy0)</div><div class='quotemain'><!--QuoteEBegin-->looks like the reverse lights may have gone as well (are they on the same fuse/earth wire does anyone know - could this have anything to do with my auto box not working ('s' BUTTON FLASHES N HAVE TO CHANGE GEARS MANUALLY)<!--QuoteEnd--></div><!--QuoteEEnd-->
If your fuel comp is still showing the time then its not the fuse, You could ask Ian for advice about the fuel comp on here -
<a href="http://www.abs-zero.com/FCprogramming.htm" target="_blank">www.abs-zero.com/FCprogramming.htm</a>
just checked the page and its offline at the moment but try at a later time.
Reverse lights and auto box are not on the same fuse
Automatic transmission fuse number 16 - 10a
Reverse lamps fuse number 22 - 10a
Dont know if this helps you.
by niggy0 » Thu Jul 07, 2005 1:02 pm
now the engine management lights don't come on at all (not even when I turn the ignition on)Could this be to do with the Ecu???????
niggy0
by callymental » Tue Jul 12, 2005 1:06 pm
If you find you need a replacement fuel comp I have a few going spare. UNfortunately I can't help with your problem.
callymental
by pr0xZen » Fri Mar 17, 2006 5:49 pm
Did you figure it out? Just installed my FC from a Carlton CDX into my 8v. The buttons didn't fit, but read somwhere that the pin numbering was the same so got it wired up with spade connectors.
The FC only displays time, and does so well. I can set the minutes, button for hours gives no reaction. I can "activate" the clock. Other than that its dead, no reaction in top or "vertical display".
Anyone? I'm totally lost here.
pr0xZen
by Cozy » Fri Mar 17, 2006 6:43 pm
if its got a little F in the corner, then its the fuse , i had a similar problem when i stuck an air inflator into the ciggerette lighter and it popped the fuse, its a 20 amp blue fuse and if u pull down the fuse box it shows where it goes
Cozy
by pr0xZen » Fri Mar 17, 2006 7:41 pm
I found the problem to be a loose connection in the FC yellow socket. Soldered, now it works. ish. still need to get the chip to Ian and sort out the temp sensor.
Anyone know the pin-outs on the FC plug? I know I need a blue and blue/white lead - but theres tons on blue leads there.
pr0xZen
