Airbag on a 1992 calibra turbo 4x4
I was wondering whether is possible to install a driver and passengers airbag on my car.
what will i need (ecu, airbags, loom, sensors, etc) and is there a different loom that i have to buy? how much would it cost and is there a wiring diagram i can show to an electrician to install it?
anyone having a complete kit to sell?
tb303
firstly if your car has the tilt steering coloumn then it will not fit you would need the steering coloumn out of a car which has had the air bag fitted after that you need to change your dash to fit the passenger air but the good news is while the dash is out it is simple to install all the wiring i have carried this out before on some one car and it took me two days start to finish oh and then you may need to change your speedo unit though this is not always the case one last thing the only to test if you got it right is to drive your car head on into a wall at over 30 mph if all is wall your air bags will go of if not you will have one head ach
mrvaux
