Dipped beam warning light on but all bulbs ok?
by gremlin » Mon May 30, 2005 11:08 pm
My dipped beam warning light comes on when i turn my lights on but i have checked all my bulbs and they all seem ok! Am i missing something?
gremlin
by Kieran_Burns » Mon May 30, 2005 11:09 pm
parking lights.... I can never remember if they are on the same warning circuit....
Kieran_Burns
by gremlin » Mon May 30, 2005 11:28 pm
Thanks Kieran i will double check that to see if they are missing. Been bugging me a bit as everthing i have checked seems to be working!
gremlin
by lammy » Fri Jun 03, 2005 11:39 pm
I heard that if you have recently changed one bulb? its worth changing the other and may sort the pob..I know i had to do this recently with a rear brakelight bulb...something to do with voltage detection...I may be wrong but its worth a try to get that light out. I know how annoying they are!
SE9
by pr0xZen » Sun Nov 27, 2005 12:27 am
Bumping an old thread, but I myself have this problem. The only broken bulb is the left foglight. Dunno how to exchange this, or if its possible - but possible the foglights are on the same circuit?
pr0xZen
by ROG » Sun Nov 27, 2005 9:53 am
you seem to have to change left and right bulbs at the same time they have to be the same type and age it seems!, i changed one side light bulb and the warning light would come one a few min after turning the lights on even though they worked fine and the 4x4 would turn off at the same time,
when i was having the clutch done i told VTS and they said they thought theyd had it before and checked back and found that if they changed both the bulbs at the back and it was sorted, both needed to be the same
ROG
by Tim2001 » Sun Nov 27, 2005 9:59 am
<!--QuoteBegin-pr0xZen+--><div class='quotetop'>(pr0xZen)</div><div class='quotemain'><!--QuoteEBegin-->Bumping an old thread, but I myself have this problem. The only broken bulb is the left foglight. Dunno how to exchange this, or if its possible - but possible the foglights are on the same circuit?<!--QuoteEnd--></div><!--QuoteEEnd-->
Al the lights are on the same circuitessentially a bulb out warning light.
Could be as simple as a brake light at the rear which your probably not checking due to having to be in the car at the time.
the fog light is a simple procedure to change its more or less just like any other bulb
Tim2001
