brake pad sensor
brake pad sensor
by Tattooman » Mon Jun 13, 2005 1:04 pm
i have a 1995 calibra 2.0 16v. i have had a v6 brake kit fitted(calipers,discs,pads). my original sensor won't fit inside the caliper thus i have the orange light on the dash constantly.would a v6 brake pad sensor attach to the wiring harness of my car and fit inside the pad or is it a different fitting? i assume it would just be a case of unplugging my sensor from the harness and plugging in the new v6 sensor?
Tattooman
by SukySaggi » Tue Jun 14, 2005 1:57 pm
Don't know. You could go to a main dealer and ask to see both sensors and check that way. Alternatively you could short the sensor to get rid of the light in the dash.
SukySaggi
by 4x4Turbo » Tue Jun 14, 2005 2:03 pm
i always used to get the light flicking on and of so in the end i shorted them out never had a problem since
4x4Turbo
by Dan Willis » Tue Jun 14, 2005 2:30 pm
Yep, strip the two wires back and tape/bond them together.
Dan
by Tattooman » Tue Jun 14, 2005 4:36 pm
Dan,you mean cut the connector off the end that goes into the caliper then join the two wires together?
Tattooman
by Dan Willis » Tue Jun 14, 2005 4:44 pm
Yes. I had to do this with my brake conversion.
Dan
by Tattooman » Tue Jun 14, 2005 6:24 pm
thanks Dan,will give it a go at the weekend [img]/smile.gif[/img]
Tattooman
by lammy » Wed Jun 15, 2005 3:36 pm
Yeah..i was able to pull the connector apart without removing the pad sensor and worrying about having to tie it off somewhere. Just put a small piece of fuse wire in the two holes on the top part of the connector you will find attached to the inner wheelarch, i then pushed it back together and the light was out on the dash!..yipeeeee no more annoying dash light...one on each front wheel. Just remember to keep an eye on pad wear!
SE9
by steve3000 » Thu Jun 16, 2005 1:04 pm
<!--QuoteBegin-Tattooman+--><div class='quotetop'>(Tattooman)</div><div class='quotemain'><!--QuoteEBegin-->would a v6 brake pad sensor attach to the wiring harness of my car and fit inside the pad or is it a different fitting? i assume it would just be a case of unplugging my sensor from the harness and plugging in the new v6 sensor?<!--QuoteEnd--></div><!--QuoteEEnd-->
Yes that'd work, did this to a mate's car, no probs.
Also had a go a hacking/filing down a set of 16v pad sensors to fit my v6 pads on my old cally after vaux sold me the wrong ones. That worked too but lot of effort...
Easiest way is to shove a paper clip in the pad-sensor connector [img]/smile.gif[/img] then tape up with a bit of insulating tape - no probs!
Steve
by Tattooman » Thu Jun 16, 2005 5:43 pm
job done,didn't have to take the wheels off either [img]/smile.gif[/img]
Tattooman
by RobbieV » Thu Jun 16, 2005 6:13 pm
Another problem sorted thanks to the wonderful people on ClubCalibra.Net :cool:
Nice [img]/smile.gif[/img]
Users browsing this forum: No registered users and 93 guests
