help needed for total closure
i have had my cobra alarm system for a year now but the one thing that has alwasy bugged me is that i know it can close the windows but the guy who fitted it never wired it up i have just had a late spring clean and came across the instruction manual and i have read it but not sure on the wires needed i have BROWN/WHITE for window closer output what else im i looking for and also what color wires do i need to connect to on the calibra 93redtp on a L reg many thanks will
wilza0
right then i have done what you said i pulled all the carpet back took out the kick panel and found the loom comming from the door grommet i used a test light plugged one end to the door to earth and prodded the cabels with the pin found two black/brown wires finally the door locks went and the windows went up great so stripped out the other side and and looked for the cobra system wire but when connected the made up wire to go between nothing now im stuck any ideas wold be great as i know you can do it cheers will
wilza0
im pretty sure you have to have the control unit with the cobra alarm its a seperate module im pretty sure thats what mines got, might be worth just running it into a cobra insatller they'll probly do it in 10 secs and just give the bloke a drink! also i think you have to program the cobra alarm to turn on the window closure
4x4Turbo
