How to wire up a oil & volt gauge.
I have just bought an oil and volt gauge (the one that sits under the stereo) but it has no wires. Does anybody know the best way to wire these up? The voltage one wont be a problem but I need to know what the pins are on the back of the gauges housing seeing as I have no plug for it.
As for the oil one I need help!!!
Anybody got any ideas?
Cheers,
Cheers,
Toddy
<a href="http://homepage.ntlworld.com/cavweb2000/pix/gauges.jpg" target="_blank">http://homepage.ntlworld.com/cavweb2000/pix/gauges.jpg</a>
that should help with the pins
for the oil gauge to work your going to have to change the switch thats at the back of the oil pump to the oil pressure duel type ...then you need to run a wire from the gauges down to the sender unit .
I just got one from Local motor factors ....was for the astra GTE but works just fine
