Airbag Light is on
FAO CRAIG ATHA Urgent
Came on last night and pops back on after the ECU check.
Anyone got any ideas on where to look and what to do?
Kieran_Burns
Checking the airbag can be risky, but do it properly and you won't have anything to worry about.
I'd start by disconnecting the battery from the car and leaving it for about 10 minutes (this is longer than necessary). Then I'd take the airbag off the wheel and check the orange plug is connected correctly behind there. If you have a passenger airbag then do the same over that side as well.
If they're all seated correctly then it could be the control unit which is located under the centre console between the front seats.
In any case, the system won't be working at the moment and needs Vauxhall to reset it with a Tech 1 to clear and get functioning again. At about £20 a pop though, you might be better off seeing if Vauxhall can tell you which part of the system is causing the fault, and concentrate from there.
Smurf
Donny 2004 Craig Atha
Actually it's 30 minutes after battery disconnection that you can "safely" remove the airbag wheel... in practice it would be less but would you risk it?
Dan
Users browsing this forum: No registered users and 80 guests
