Anyone relocated battery to the boot?
by Chavtastic » Sat Jul 02, 2005 1:52 pm
If so any advice or pictures?
Obviously I'll have to fuse the main power wire at both ends running through the car. I am using "0" gauge wire.
1. How would I earth the battery in the boot? Drill and tap a nice hole into the chassis? Or run a wire to the loom in the engine bay?
2. Any ideas on good places to get power splitters so I can join the loom into one single wire in the engine bay.
by Sg-1 » Sat Jul 02, 2005 7:37 pm
<!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->Please excuse my ignorance, but why?<!--sizec--></span><!--/sizec-->
by Chavtastic » Sun Jul 03, 2005 10:24 am
<!--QuoteBegin-Sg-1+--><div class='quotetop'>(Sg-1)</div><div class='quotemain'><!--QuoteEBegin--><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->Please excuse my ignorance, but why?<!--sizec--></span><!--/sizec--><!--QuoteEnd--></div><!--QuoteEEnd-->
There's no obvious reason, but:
1. Space for water injection tank and other bits in engine bay
2. Better weight distribution (less weight in front!)
by warby » Fri Jul 08, 2005 12:26 pm
i have put another battery in to run all my amps it behind the amp on the left also got a charge unit in for when my engines running
warby
by TommyC » Fri Jul 08, 2005 2:19 pm
<!--QuoteBegin-CalibraTurbo99+--><div class='quotetop'>(CalibraTurbo99)</div><div class='quotemain'><!--QuoteEBegin-->If so any advice or pictures?
1. How would I earth the battery in the boot? Drill and tap a nice hole into the chassis? Or run a wire to the loom in the engine bay?<!--QuoteEnd--></div><!--QuoteEEnd-->
You could try earthing it on one of the rear seatbelt mounts?! Clean off the paint and sandwich it in between?? Gotta make sure the electrical continuity is there and good tho cos othewise you'll have all sorts of problems.....
Might be worth contacting retro cars magazine cos they did a guide to re-locating your battery to the boot a while ago. Alright it's for older cars and they might tell you to buy a back issue, but it'll be better than non-specific advice!!!
TommyC
by trev150 » Sun Jul 10, 2005 11:15 pm
Just extend the power wire to the boot.
And place all of the earth to a clean point on the chasis in the engine bay.
Earth the battery in the boot as close as possible to where it is located.
by Chavtastic » Mon Jul 11, 2005 5:11 am
Okay guys no problems.
As for fusing should I just have a couple of heavy duty fuses at each end of the power cable?
by trev150 » Mon Jul 11, 2005 11:38 pm
yes mate.
Just measure the full load current out put of the alternator and fuse it the next step higher.
One fuse in the engine bay will be sufficient.
Users browsing this forum: No registered users and 88 guests
