fuel computer info?
fuel computer info?
by Iva Biggen » Fri Jul 15, 2005 1:07 pm
hey dudes, it's bloody hot!
right, looking to put a fuel computer in my '92 cally (16v 2.0), just a few quickies [img]/smile.gif[/img]
1. Do I need to get hold of any extra sensors?
2. Is CALIBRAting it easy? [img]/wink.gif[/img]
3. I know i better check under the centre console first to see if i can put the plug in there.
4. is it simply plug and play?
cheers folks,
Matt
Iva Biggen
by wilza0 » Fri Jul 15, 2005 3:37 pm
as its a 92 better check to see if you have the yellow plug mate take the glove box out and see to the left the main wiring loom wrapped in sponge tape if the yellow plugs there you should be ok you will need to wire the switch tho i can send you a wiring diagram if you need
wilza0
by Iva Biggen » Fri Jul 15, 2005 4:12 pm
ah, will have to do that when i get it back from the paint fella, gonna be one tidy, debadged mo fo! [img]/smile.gif[/img]
Iva Biggen
by sofaman » Sat Jul 16, 2005 12:47 am
If u have the wire, u need
Fuel computer + switch
Outside temp sensor (I hear about £15 form VX but don't quote me)
Black trim panel for around the comp
Fitting is , remove clock. connect fuel comp. remove the center console to fit the switch were the coin hloder is (plugs in next to the elec window connectors).Fit temp sensor in the front bumper (right hand side as u look at the car), the should be a connector with a two blue wire (think one of the wires has a white tracer).
Test the computer to see if it reads right (get a long road and reset the avg speed and see if the new speed matches yours). If not you will need it calibrating (do a search on here). He does it for a tenner on standard cars and did mine a treat [img]/biggrin.gif[/img]
If the fuel reading is wrong then u need a 6ohm resistor (post if instruction are needed).
Think thats about it, there is a guide in the guides + articals section on here.
Just hope u have the connect, I had to remove my cd player to find mine
Good luck
sofaman
by Iva Biggen » Sun Jul 17, 2005 10:52 am
top stuff dudes, and thanks for all the installation info sofa, will get to it when me car arrives home! [img]/smile.gif[/img]
Iva Biggen
