Rear reg plate light
my rear reg plate light isnt working and ive changed the bulb but still not working, all the other lights are working as they should,
Could the actual unit itself be stuffed and need replacing or could it be something else ???
thanks for any help [img]/smile.gif[/img]
forgot to mention is was for the omega!
c1emm
Rusty_CallyT
If any of the contacts have corroded like they did on mine then there won't be a good enough conduct of electricity. Check it and if needbe, either clean it up or replace it....you could get a cheapy for 1 or 2 quid from the breakers.
Failing that, check the wires to make sure there are no breaks in them.
