Dodgy Indicator.
Dodgy Indicator.
Indicator works sometimes, then other times it does not,
new bulb gone in, new relay, indicator stalk.
Also my ABS light comes on when I reverse, tho reverse lights
are working.
Anyone put me in the right direction please?
Cheers.
are working.
Cheers.
VivSE5
sounds like a dodgy connection or break in the wiring for the indicator, not really something that can be traced without looking at the car etc.. you'll probably have to get an auto elec guy on the case [img]/smile.gif[/img]
The abs should be readable tho, to find out what the problem is.. It is quite likely just the sensors/cogs around them wanting a clean though.. <a href="http://www.topbuzz.co.uk/info/abs_codes/abs_codes.htm" target="_blank">http://www.topbuzz.co.uk/info/abs_codes/abs_codes.htm</a>
