Foglight wiring
Foglight wiring
by King Calibra » Fri Sep 30, 2005 1:36 am
Is the wiring needed for the foglights fitted on all Calibras? Just curious because the wiring for the switch is there, and I plan on fitting headlights with foglights.
King Calibra
by Proxie » Fri Sep 30, 2005 2:36 am
Usually it is [img]/smile.gif[/img] same is with height adjustable lights
Proxie
by King Calibra » Fri Sep 30, 2005 11:45 am
<!--QuoteBegin-Proxie+--><div class='quotetop'>(Proxie)</div><div class='quotemain'><!--QuoteEBegin-->Usually it is [img]/smile.gif[/img] same is with height adjustable lights<!--QuoteEnd--></div><!--QuoteEEnd-->
Would you be able to snap a photo of where it's supposed to be?
King Calibra
by Proxie » Fri Sep 30, 2005 4:25 pm
<!--QuoteBegin-King Calibra+--><div class='quotetop'>(King Calibra)</div><div class='quotemain'><!--QuoteEBegin-->Would you be able to snap a photo of where it's supposed to be?<!--QuoteEnd--></div><!--QuoteEEnd-->
The switch for height adjusting is just to be plugget in. No relays are needed.
Very close to each headlamp is this connector:
<a href="http://www.calibra.dk/lex/img_2325.jpg" target="_blank">http://www.calibra.dk/lex/img_2325.jpg</a>
It's to be connected to height adjustable motor on headlamp
cheers Proxie
Proxie
by ecosseM » Fri Sep 30, 2005 5:01 pm
i fitted front fogs into my 1995 se4, all i needed for that was 2x headlights(with fogs/16v) relay and the switch..all wires are there, pretty much std looms on most calibras
ecosseM
by King Calibra » Fri Sep 30, 2005 10:06 pm
<!--QuoteBegin-Proxie+--><div class='quotetop'>(Proxie)</div><div class='quotemain'><!--QuoteEBegin-->The switch for height adjusting is just to be plugget in. No relays are needed.
cheers Proxie<!--QuoteEnd--></div><!--QuoteEEnd-->
Actually, I meant the connector for the foglights.
King Calibra
by ROG » Fri Sep 30, 2005 10:15 pm
all wires are in the big multi pin plug to the headlights
ROG
by King Calibra » Fri Sep 30, 2005 10:17 pm
<!--QuoteBegin-ROG+--><div class='quotetop'>(ROG)</div><div class='quotemain'><!--QuoteEBegin-->all wires are in the big multi pin plug to the headlights<!--QuoteEnd--></div><!--QuoteEEnd-->
So all I need to do is plug the lights in and it'll work?
King Calibra
Users browsing this forum: Google [Bot] and 17 guests
