Glovebox light / cigarette lighter
by malcolm_jamesuk » Tue Oct 25, 2005 12:52 pm
Hi all hope u are all well ..... just noticed that the glovebox light does not work - obviously checked the bulb with a battery and hey presto it works.... , ... noticed that the cigarette lighter does not light up also ...? Had a quick look in the fuse box ...unfortunately i do not have an owners manual so i do not know which fuse to check ....at first glance all seems well and i could not see any obviouse blown fuses.... any ideas out there please .... is this common .... ??
Many thanks all the best Malc
malcolm_jamesuk
by Mong0L » Tue Oct 25, 2005 12:56 pm
<a href="http://www.clubcalibra.net/forum/showthread.php?t=9540" target="_blank">http://www.clubcalibra.net/forum/showthread.php?t=9540</a>
has all the fuses listed here, maybe a start [img]/smile.gif[/img]
Mong0L
by malcolm_jamesuk » Tue Oct 25, 2005 12:59 pm
Thanks very much will have a look
malcolm_jamesuk
by malcolm_jamesuk » Tue Oct 25, 2005 2:04 pm
No fuses "popped".................
malcolm_jamesuk
by Fraz » Tue Oct 25, 2005 4:41 pm
now I dont want to tell you how to suck eggs ...but you are aware they both only work when the igmtion is on?
by Animal » Tue Oct 25, 2005 6:28 pm
I found mine didnt work when I got it. Turned out it was the switch for it. Rubbish design. Bent it a bit swore at it a bit and it worked! [img]/biggrin.gif[/img]
by daddycool » Tue Oct 25, 2005 9:34 pm
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->now I dont want to tell you how to suck eggs ...but you are aware they both only work when the igmtion is on?<!--QuoteEnd--></div><!--QuoteEEnd-->I was gonna say that!
daddycool
by malcolm_jamesuk » Wed Oct 26, 2005 7:58 am
I am aware that they only work when the ignition is on ......ta ....... as you can see the main problem is they don't work at all..it's not a huge problem defintely not loosing muck sleep over it.... but it starts to niggle you , then you think " i i'll just have a look at this - then that , before u know it youv'e got screws / bits of car everywhere ...........................i will take a look at the switch on the weekend see if that has anything to do with the glove box light .,, many thanks all the bestto you all.
malc
malcolm_jamesuk
Users browsing this forum: Bing [Bot] and 15 guests
