Electric windows dead.
Replaced centre console switches with known good unit.
Checked the two listed fuses, F30 and ??F12?? cant remember the second one but its the one shared with the mirrors, and the mirrros work ok as well..
Next port of call??
The little illumination works when the door is opened, but no life up/down from either window doors open or shut.
Not a keen electrics fan [img]/smile.gif[/img]
Next port of call??
ahh.. i dont have haynes.. I will have another nose during the week with my multimeter and see what i can work out, test the switch and see where power is etc.
If you should have a flash of inspiration and remember that would be quite usefull, i dunno where to look next :- I guess strip a door panel off and test for power at the motor might be an idea..
Have you checked both the fuses and tried the centre consol panel??
My guess is that there is a relay somewhere, the wiring to the switches don't look very beefy.. Anyone know if there is a relay for them? one of the two fuses for the windows is 30amp.. these poxy switches won't run 30amp imo.
