Electric Window gone MAD!!!!!
by criscali » Mon Nov 07, 2005 8:14 pm
Hey all my drivers side window has just developed a mind of its own! if i push the button to stop it on its way up or down, it wont stop, it just moves to a set position, the same everytime, then moves down a bit, then stops. its always the same position, it always moves then stops then moves then stops exactly the same positions everytime. its driving me mad coz i cant figure it out! any ideas?
criscali
by Stupink » Mon Nov 07, 2005 8:35 pm
First step is to try and reprogramme it.
open the door..
press the down button and hold once the window is fully down for another 5 seconds.
repeat with the up button..
see what it does then..
by criscali » Tue Nov 08, 2005 11:03 am
Cheers Stu, tried this but no luck. it still does the same, someone said it might be the printed circuit in the window motor, what do you think?
cheers Cris.
criscali
by SukySaggi » Tue Nov 08, 2005 11:06 am
I didn't think there was a pcb on the motors. There is one which is part of the switches though.
SukySaggi
by criscali » Tue Nov 08, 2005 11:10 am
So you reckon it could just be a dodgy switch then? might be a good excuse to get rid and replace it with a blue led one [img]/smile.gif[/img]
Thanks 4 the advice mate ill have a look!
Stu have you had any luck with your windows mate?
Cris.
criscali
by Stupink » Tue Nov 08, 2005 7:39 pm
mine are still fried.. i've not had time to look at them really.
there is a controll unit on the motors, but the "ecu" as it were is part of the switch bit in the centre consol [img]/smile.gif[/img]
by Welsh Chris » Wed Nov 09, 2005 11:15 pm
I just bought a calibra and a similar thing with the windows has happened they will go most of the way up but will stop about 2" from the top and come back down
Any help please would be greatful as im new on this site please lads
Welsh Chris
by criscali » Thu Nov 10, 2005 2:19 pm
Hi matey, im about to go down the breakys and get a window switch, ill let you know if it works.....
criscali
by criscali » Thu Nov 17, 2005 4:26 pm
hey chris, i tried a different switch mate, this didnt sort it, so i pulled out the fuse and put it back in and its fine! had to reprogramme it, see stu's advice above for how to do this mate!
criscali
by Kieran_Burns » Thu Nov 17, 2005 4:49 pm
<!--QuoteBegin-Welsh Chris+--><div class='quotetop'>(Welsh Chris)</div><div class='quotemain'><!--QuoteEBegin-->I just bought a calibra and a similar thing with the windows has happened they will go most of the way up but will stop about 2" from the top and come back down
Any help please would be greatful as im new on this site please lads<!--QuoteEnd--></div><!--QuoteEEnd-->
That's the sensor that stops your head getting trapped... you need to grease your rubber! [img]/wink.gif[/img]
Clean the rubber on the pillar and apply some grease - I find lithium grease to be the best to use.
(oh, and stop hi-jacking threads [img]/wink.gif[/img] )
Kieran_Burns
