indicator lights stay on
by ecosseM » Sat Nov 12, 2005 6:01 pm
any ideas? when went out to car i kept hearing a buzzing (like a relay play'n up) noise from the passenger front side of the car, glove box area, and lights on the dash kept comming on and of as buzzed..
now no buzzing and indicators are staying on, even with fuse and relay removed from the fuse box..
got stripped down on the n/s/f but cant see any relays in there.. :confused:
ecosseM
by Fraz » Sat Nov 12, 2005 6:03 pm
could be the alarm module as no doubt that is wired to the indicators
by ecosseM » Sat Nov 12, 2005 6:05 pm
aye, thats the only thing i can see up there.. but can find any books/manuals that help here.. cars!!!! lol
ecosseM
by RobbieV » Sat Nov 12, 2005 6:29 pm
Check your hazzard switch, i had a similar problem once turned out to be the switch [img]/smile.gif[/img]
by ecosseM » Sun Nov 13, 2005 5:45 pm
found, how to switch indicators off, unplug the imobilser unit, or battery..
anyone got any ideas what would cause that with the imob unit? or how to fix hmm
had a look threw the haynes manual, it conects up threw many different parts of the car, light sensors, radio(?),rear heated screen, indicators..........
cant see it being cheep to replace if need new imobiliser system fitted, grrrr
ecosseM
by Robs-se » Tue Nov 15, 2005 3:17 pm
Have you checked ALL your exterior bulbs. mine did this sometime back
and tuned out to be a blown bulb caused by the metal connections being a bit corroded.
Rob
