VDO gauges
VDO gauges
by mdav1970 » Fri Dec 16, 2005 10:33 pm
Does any one now if a 94 V6 Calibra have the wiring plug loom etc for the centre consule oil and volt gauges?
mdav1970
by wilza0 » Fri Dec 16, 2005 10:58 pm
no you will need to tapp into the radio or clock for the volt and you will need a oil pressure sender you will also need to go to a pc shop as they sell a lead with the correct pin connector its like a cdrom cable hope this helps if you need a wiring diagram i have one handy i will email it if you require cheers will
wilza0
by mdav1970 » Fri Dec 16, 2005 11:06 pm
chears i will let you know about wiring diagram.
mdav1970
by callymental » Mon Dec 19, 2005 12:20 pm
cavweb.co.uk has all the info you need for this.
callymental
Users browsing this forum: No registered users and 103 guests
