Fuses
Reverse switch almost guaranteed mate, had mine go few weeks ago, should be a small plug on front edge of gearbox, simply unscrew and replace, got mine from Halfrauds for £4. Simple test, unplug connection, bridge with piece of wire, ignition on and see if it pops then. If it doesnt its your switch.
richardworrall
<!--QuoteBegin-Trig+--><div class='quotetop'>(Trig)</div><div class='quotemain'><!--QuoteEBegin-->Fuse 22 keeps blowing, TC, check lights and reverse lights, bulbs are ok in the back n thats about as far as I get to checking.
This common, anywhere else I should be checking?<!--QuoteEnd--></div><!--QuoteEEnd-->
TC?? sounds like traction control. Have you changed bulbs recently?
joseito
