Toad Ai606 LED
Toad Ai606 LED
by rob » Wed Jan 18, 2006 12:13 am
Righty then after I wired it myself and everything was fine a few days later the LED stopped working properly and is now on permanent green, Is the LED Brock or something else
rob
by daddycool » Wed Jan 18, 2006 6:10 pm
Does the alarm work correctly?
daddycool
by Welsh_Andy » Wed Jan 18, 2006 6:17 pm
permament green is unarmed iirc when i press button(unlock) it goes to green,but only for 30secs then bk to red,can you still lock the car with the remote? if yes does it still stay green, are you getting 2 bleeps when armed/unarmed
Welsh_Andy
by WillsToy » Wed Jan 18, 2006 6:33 pm
<!--QuoteBegin-Welsh_Andy+--><div class='quotetop'>(Welsh_Andy)</div><div class='quotemain'><!--QuoteEBegin-->permament green is unarmed iirc when i press button(unlock) it goes to green,but only for 30secs then bk to red,can you still lock the car with the remote? if yes does it still stay green, are you getting 2 bleeps when armed/unarmed<!--QuoteEnd--></div><!--QuoteEEnd-->
sounds about right to me, think your immobilser is not working, leave the window and set the alarm after 30 secs stick you hand in and see if internals sensors are working.
Like andy said how many bleeps do you get when setting the alarm?? any more than 1 and you have a fault.
You may of put it in valet mode,but with the toad it's not easy to do, lots of flashing light counting and key twisting,
Will
WillsToy
by rob » Wed Jan 18, 2006 9:13 pm
<!--QuoteBegin-WillsToy+--><div class='quotetop'>(WillsToy)</div><div class='quotemain'><!--QuoteEBegin-->sounds about right to me, think your immobiliser is not working, leave the window and set the alarm after 30 secs stick you hand in and see if internals sensors are working.
Like Andy said how many bleeps do you get when setting the alarm?? any more than 1 and you have a fault.
Will<!--QuoteEnd--></div><!--QuoteEEnd-->
Alarm is ok as I get 1 beep on arm and 2 of disarm and also immobiliser as well like when I leave it unarmed for a bit it kicks in and it wont start.
I dont have internals sensors just a brake glass sensor.
rob
by rob » Mon Feb 13, 2006 10:34 pm
btttttt
rob
by MR_TOAD » Sat Feb 18, 2006 5:10 pm
<!--QuoteBegin-rob+--><div class='quotetop'>(rob)</div><div class='quotemain'><!--QuoteEBegin-->btttttt<!--QuoteEnd--></div><!--QuoteEEnd-->
Sounds like an ECU fault inside alarm or LED fault how long have you had alarm
and was it on when you got it or did uou have it fitted ?
Ian
MR_TOAD
Users browsing this forum: No registered users and 102 guests
