Heated seat cable?
Heated seat cable?
on the driver seat of my 93 cally, there are two cables (a brown&yellow one, and a brown one) that come out of the back support of the seat, they come out were the seatbelt clips in. the heated seat is connected under the seat, this cable goes straight up into the base part. any ideas what these cables are for? they are cut off and have no plug on them. are the back supports of the chair supposed 2 be heated? i dont think mine works,should they be connected inside the seat somehow?! cheers
Doodley
THe backs should be heated. The cable from the base of the back should be connected to the wires in the base. They often split due to the poor location the wires were located. Solder them back together and you'll be great. Pass the wires away from the seat hinge too, to avoid it happening again.
callymental
