wiring AFR
by LE28 » Sat Apr 24, 2004 9:03 pm
3 WIRE SENSOR,do i wire it from the oxygen sensor or do i trace the wires back to the ecu and go from there. :oops:
LE28
by Naz » Mon Apr 26, 2004 12:48 am
its up to you. wouldn't do it form the ecu side as the space is really restricted. Fit it through the bulk head and then tap it into the wires from the lambda sensor. Thats what i havedone.
Naz
by splinter » Mon Apr 26, 2004 3:49 am
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Fit it through the bulk head and then tap it into the wires from the lambda sensor.<!--QuoteEnd--></div><!--QuoteEEnd-->
Ive done mine like that too. [img]/smile.gif[/img]
The old skyline gtr felt exciting even when it was in a car wash !!!!! :)
by Dan Willis » Mon Apr 26, 2004 9:22 am
Same here (black wire of the three). MUCH simpler!
Dan
Knocking noise from wheel
by LE28 » Mon Apr 26, 2004 8:59 pm
cheers lads :oops:
LE28
by SecondOne » Mon Jul 12, 2004 8:08 pm
got any pics ????
SecondOne
HOT CRUISER EVENT, SHEFFIELD ARENA JULY 24TH
by Stupink » Mon Jul 12, 2004 8:22 pm
yes tap onto it in the engine bay as everyone has said.. do it inbetween the sensor and the connector up by the brake servo, that way any problems and it can be replaced with a new sensor.
Wire the earth to a GOOD ground on the engine its self, that way it shares earth with the sensor itself to avoid voltage drop across the origional loom etc...
And wire the plus to a good stong life switched feed, depending where you firt your gauge directly off the ignition barrel is quite handy [img]/smile.gif[/img] other power feeds for peripherals radio/lighter/lights etc etc again all suffer poor voltage regulation and a fair drop so can cause some again to give poor/false readings [img]/smile.gif[/img]
Users browsing this forum: Bing [Bot] and 28 guests
