alarm not workin
alarm not workin
ok robbiev has pointed me in the direction of <a href="http://www.v6calibra.com/alarm/v6calibra_atas.htm" target="_blank">http://www.v6calibra.com/alarm/v6calibra_atas.htm</a> so thanx for that, only problem is my LED dont even flash. dont no much bout cally electrics, so where are the fuses and connections i shld b looking for?
projectcalibra
<!--QuoteBegin-projectcalibra+--><div class='quotetop'>(projectcalibra)</div><div class='quotemain'><!--QuoteEBegin-->how do i no if a relay works
<!--QuoteEnd--></div><!--QuoteEEnd-->
Dunno, but some bright spark will tell you soon [img]/smile.gif[/img]
ok cldnt find the relays, but did press the pet button and we now have the led working. basically, it flashes slowly for a few secs, then goes into a crazy flashing mode. locked someone in the car, they move around and alarm dont sound, they unlock it from inside and again, no alarm noise. any ideas?
projectcalibra
<!--QuoteBegin-jimbo1979+--><div class='quotetop'>(jimbo1979)</div><div class='quotemain'><!--QuoteEBegin-->Are you supposed to have a key fob for these alarms? Never bothered looking at them in either of my cali's?
Or are they set when you lock the car?
Is there a way to test it?
Thanks
And sorry for jumping on your thread<!--QuoteEnd--></div><!--QuoteEEnd-->
Calibra's dont come with key fobs for locking and switching the alarm on, thats an aftermarket kit.
For more info look here
Thanks
projectcalibra
<!--QuoteBegin-projectcalibra+--><div class='quotetop'>(projectcalibra)</div><div class='quotemain'><!--QuoteEBegin-->Fault codes can be read out of the Alarm by shorting pins A and H
where are the pins?<!--QuoteEnd--></div><!--QuoteEEnd-->
Use this guide but short out pins A & H with a paperclip or bit of wire [img]/smile.gif[/img]
<a href="http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm" target="_blank">http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm</a>
<!--QuoteBegin-projectcalibra+--><div class='quotetop'>(projectcalibra)</div><div class='quotemain'><!--QuoteEBegin-->do u just count the flashes on the sensor LED? will it do 1 fault, pause and move on, or how does it work?<!--QuoteEnd--></div><!--QuoteEEnd-->
Sorry ive never done the test.
<!--QuoteBegin-projectcalibra+--><div class='quotetop'>(projectcalibra)</div><div class='quotemain'><!--QuoteEBegin-->all sorted, nothing wrong with it, just its not set off by the ways we tried, leave bonnet open when u activate it and it goes off<!--QuoteEnd--></div><!--QuoteEEnd-->
Well done for getting there [img]/smile.gif[/img]
Users browsing this forum: No registered users and 50 guests
