Control Indicators?????
OK so i decide to pull aprt my dash as none of my control indicators were lit.
You know the ones, windscreen washer empty/oil level low/coolant low/brake bulb failure etc etc
Well bugger me sideways with an banana, pulled the dash aprt in 15mins, many thanks to Fraz for the guide it worked a treat!!! :thumb:
But when i looked on the back of the instrument binnacle, i noticed that i had no leads/wires running to the slots that would hold the bulbs in .
So my question is,
1)did all calibra's have the check system?
2)or is there something missing from mine? 95 M plate se4
3)If you look at the other side there seems to be an underlay which i guess mime should have on the other side but dosent???
I have some pics will post up later
Well cheesed now as i thought i would be able to sort it all out, guess i will plug it all back in with only 1 bulb replaced :sob:
Will
So my question is,
Will
WillsToy
OK a few pics, hope you guys get what mean above , but it seems it may be an option and not a standard fit jobbie
sorry for delay and only a camera phone
<a href="http://dooberywhatsit.com//files/Dash1.jpg" target="_blank">http://dooberywhatsit.com//files/Dash1.jpg</a>
<a href="http://dooberywhatsit.com//files/Dash2.jpg" target="_blank">http://dooberywhatsit.com//files/Dash2.jpg</a>
<a href="http://dooberywhatsit.com//files/Dash3.jpg" target="_blank">http://dooberywhatsit.com//files/Dash3.jpg</a>
as you look at the pics i put a new bulb in slot 18 but left the others as i dont have 4x4 and TC etc
cheers
Will
cheers
Will
WillsToy
By the looks of those pics i would say your car does not have the check control system, there are no +/- feeds to the bulbs.
Plus i can only see two plug connectors where all other dash's ive played around with that have check control have three plug connectors.
