need help with getting to speedo cable
by ian » Sun Jun 11, 2006 9:09 am
just need a guide to getting to this without braking anything.
thanks guys
ian
by ice man » Sun Jun 11, 2006 9:27 am
What's the problem?
If you need to get the inner cable out but the outer cable is OK then you can unscrew the cable end from the gearbox and with a bit of a tug the inner will come out with a small nylon bush.
If the inner had broken you may need to remove the speedo (do a search in here) and pull the other end.
my cable had broken and I found it much easier replacing the inner only
ice man
by ice man » Sun Jun 11, 2006 12:05 pm
Unless of course it's an electronic speedo... D'oh
ice man
by ian » Sun Jun 11, 2006 12:09 pm
ive been old by the last owner that he thinks he didnt put it back on good enogh so i hope i will just have to re-conect it..
just need to know best way to get to it
thanks
ian
by Rusty_CallyT » Sun Jun 11, 2006 6:42 pm
if the speedo's working ok leave it. they are pretty rigid so i doubt it'll fall off if not fully clipped in
Rusty_CallyT
by ian » Mon Jun 12, 2006 5:49 pm
no the speedo dont work thats why i need to get to it
ian
by TonyDTM » Mon Jun 12, 2006 7:03 pm
To remove an instrument cluster.
Take off the steering column cowel top and bottem (top screws under covers behind wheel...spin it right and left 90 degrees). Take out bottem trim from cluster, you may need to prize it out with a flatblade, but its fairly flexable. Once removed you can get to the screws holding the top trim...2 by the heater control and 2 by the light switch pack. Once removed you can get to the screws holding the instrument cluster. You might find it easier to also remove the light switch. Behind the switch is a double rectangular recess for the light switch pin bushing. You can safely remove that "cardboard" piece inbetween the switch recess and it will open up a gap big enought to stick ya hand through. You can feel the clip holding the cable. It pushes down to release. To lock the cable in just push it in hard. There are 2 electrical connections. They are held by clips on either end. Push the clips in to release. If you wish to remove the cluster while the cable is off pull it forward and tilt either left or right. Makes changing bulbs to LED's and fitting bezels simple work.
Refit is reverse of removal.
TonyDTM
by Fraz » Mon Jun 12, 2006 7:48 pm
or you could try
<a href="http://www.clubcalibra.net/forum/articles.php?action=viewarticle&artid=14" target="_blank">http://www.clubcalibra.net/forum/articles....rticle&artid=14</a>
by TonyDTM » Mon Jun 12, 2006 7:50 pm
sorry Fraz m8, didn't realise you had done a "how to"
TonyDTM
by Fraz » Mon Jun 12, 2006 7:52 pm
no need to aplogize...no one every reads the guides first
by ian » Mon Jun 12, 2006 9:04 pm
cheers tony and fraz i will have a look in morning and let u know how i got on
ian
by ian » Tue Jun 13, 2006 12:04 pm
well i got to it and everything seemed ok all the plugs were in but still speedo dont work were does the other end go to so i can chex it
ian
by mevans » Wed Jun 14, 2006 12:12 pm
into the top of the gearbox
mevans
by ian » Wed Jun 14, 2006 7:05 pm
thought that was it well that in so what could be the problem ?
ian
Users browsing this forum: No registered users and 65 guests
